Thread: Running Rough - heres how to find the problem..
Results 1 to 4 of 4
  1. #1 Running Rough - heres how to find the problem..
    SE Level Member aussie's Avatar
    Dec 2011
    Woodruff, SC
    This was performed on a 1997 Grand Prix GT N/A 3800 Engine
    NOTE: I am NOT a mechanic, just a regular backyard guy…
    OK, so my problem has been a rough Idle, engine misfire…
    I had checked all the usual suspects, MAF, PCV, Spark plugs & Wires, UIM & LIM Gaskets…
    All checked out good… so where to go next…
    The only way to find the problem is with a compression test, then a leakdown test on any cylinders that seem suspect..
    You will need a compression guage, here is a link to one –
    Quick-Connect Compression Tester
    You will also need an air compressor – regulated to about 70psi
    And regular tools
    Here is the process: Cold Engine
    Remove all the spark plugs, plug wires (Label Them)
    Remove the fuse for the fuel pump.
    Open the throttle & use a screwdriver or something to hold it fully open.
    Use the compression guage on all 6 cylinders, write down the numbers
    (crank the engine for 4 or 5 revolutions)
    Depending on the miles of your engine you should see around 150-200psi on the cylinders
    If you see one or more with low numbers, they need further testing…
    Firing order : 1-6-5-4-3-2
    Find top dead center on the compression stroke of the suspect cylinder
    Put a small piece of toilet tissue in the spark plug hole, and the one prior to it in the firing order.
    Rotate the engine using a wrench on the crank pulley – clockwise
    When the paper blow out from the cylinder prior to the one you want, go slowly…
    When the paper blows from the cylinder you are testing, stop, stick a screwdriver in the spark plug hole & slowly turn the engine until you feel the piston reach top dead center.
    Remove the schraeder valve from the end of the compression tester tube & install the tube in spark plug hole.
    Remove radiator cap, oil cap & intake hose from throttle body.
    Attach air from the compressor to the compression tester hose.
    You will hear air rushing from one of these places
    Tail Pipe – bad exhaust valve
    Throttle body – bad intake valve
    Oil filler tube – bad rings
    Bubbling from radiator – Head gasket
    From adjacent spark plug hole – Head Gasket…
    I will update/edit this post when I have time
    I used as much common sense as I could find, and these 2 great resources…
    Eric the car guy video
    Google searches
    My results: I have 2 cylinders 3 & 4 that are both leaking through intake valves – showing cylinder heads need rebuilding
    My compression numbers are:
    1:135 3:65 5:180
    2:175 4:60 6:175
    I did a leak down test on cylinders 1, 3 & 4
    Cylinder 1 showed a small leak through the intake
    Cylinders 3&4 were just rushing out the intake.
  2. #2 Re: Running Rough - heres how to find the problem..
    i leak through the intake and exhaust valves.
  3. #3 Re: Running Rough - heres how to find the problem..
    Dec 2011
    Woodruff, SC
    Your SOL then...
    Or your not at TDC on the compression stroke..
  4. #4 Re: Running Rough - heres how to find the problem..
    And past the rings.
    Still made 267 WHP though.
  1. GTP running rough when hot
    By reem98 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-08-2011, 10:09 AM
  2. Running Rough
    By Kenny75k in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-26-2011, 02:02 PM
  3. running rough
    By BOOSTED GP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-09-2011, 11:58 AM
  4. GTP Running Rough.. few new parts but still not running right.. HELP
    By azmattaz06 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-29-2010, 02:34 PM
  5. so heres the problem
    By GEMINIokc in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-29-2008, 04:33 PM
