Thread: 4th Brake Light (Under Decklid)
Page 4 of 5 FirstFirst ... 2345 LastLast
Results 61 to 80 of 97
  1. #1 Re: 4th Brake Light (Under Decklid)
    Donating Users Taz Magister's Avatar
    Dec 2010
    Ohio
    whats the blue?
  2. #2 Re: 4th Brake Light (Under Decklid)
    GT Level Member chamilton89's Avatar
    Columbus, Ohio, United States
    Quote Originally Posted by Taz Magester View Post
    whats the blue?
    There is no blue, its white LED's for the reverse lights, the camera just makes it look blue because the Reverse lights are so warm.
    Infinity all around.
  3. #3 Re: 4th Brake Light (Under Decklid)
    Donating Users iroc2's Avatar
    Jul 2010
    Lansing IL
    is that eh fire and ice light bar?
    SMGPFC # 008 -White 1995 Grand Prix SE: tinted tails, Flowmaster 40 Series mufflers with resonating tips. much more to come eventually
    Quote Originally Posted by Xorbex View Post
    I almost beat the man but murphy showed up.
  4. #4 Re: 4th Brake Light (Under Decklid)
    Quote Originally Posted by iroc2 View Post
    Sure is. Very happy with it.
  5. #5 Re: 4th Brake Light (Under Decklid)
    Jul 2010
    Lansing IL
    can you create a new thread of hte work that you did in preperation of this?
  6. #6 Re: 4th Brake Light (Under Decklid)
    Yeah. Tomorrow I can make a proper writeup if you would like. I can inclue everything I did and used along with lots of pictures.
  7. #7 Re: 4th Brake Light (Under Decklid)
    Jul 2010
    Lansing IL
    Quote Originally Posted by chamilton89 View Post
    sounds great! thanks!
  8. #8 Re: 4th Brake Light (Under Decklid)
    GT Level Member EJRJR91's Avatar
    Nanuet, NY
    finally got pics of mine lol
  9. #9 Re: 4th Brake Light (Under Decklid)
    SE Level Member MakeitLouder97's Avatar
    Maryland
    im looking to do this same mod i have 2 12" strips and i want to wire them up so when i hit my bakes they come on and when i use my turn signal they come on but i dont want them to stay on when im not hitting the brake or turn signal can anyone help me
  10. #10 Re: 4th Brake Light (Under Decklid)
    Quote Originally Posted by MakeitLouder97 View Post
    you can buy sets that are programmed to do this already if you wire them correctly.
  11. #11 Re: 4th Brake Light (Under Decklid)
    You can do exactly what you want, it will be very very simple. Our Gp's brake lights are duel filament bulbs. One of the filaments is the turn signal and the break lights, the second filament is the night time running lights. All you have to do is splice the positive wire for each of your strips to there respective sides turn signal filament wire, I forget the colors but I can look tomorrow. Then splice both the grounds to the common ground all the tail lamps share. Thats all there is to it!
  12. #12 Re: 4th Brake Light (Under Decklid)
    Bay Area, California
    I'd like to see this one a 04+ as it looks super clean on all the cars I've seen so far. I would like that fire/ice set up, but would like for mine to be on while the headlights are on, plus reverse, turn signal ect.
  13. #13 Re: 4th Brake Light (Under Decklid)
    Quote Originally Posted by Pontiac Cali Guy View Post
    I'd like to see this one a 04+ as it looks super clean on all the cars I've seen so far. I would like that fire/ice set up, but would like for mine to be on while the headlights are one, plus reverse, turn signal ect.
    I love my fire and ice setup although now I have to replace the reverse lights with LED's so the whites are the same. Anyway, I really wanted to have the nighttime running lights as well, but I quickly found out this wasnt possible due to the setup of the rear lights and which bulb performs which function. If I come up with a solution, I will gladly share but right now, I got nothing.
  14. #14 Re: 4th Brake Light (Under Decklid)
    MINNESOTA
    they all look good.
    can someone please tell me where i can buy some of them led lights
    nice write up
  15. #15 Re: 4th Brake Light (Under Decklid)
    Brightening up your day. Koniig's Avatar
    Jun 2010
    Illinois.
    Stilllll not feeling this.
    Still looks too "raised 2 feet, tinted windows, 'keep honking I'm reloading' bumper sticker, train horn" truck-ish to me.
  16. #16 Re: 4th Brake Light (Under Decklid)
    Quote Originally Posted by Koniig View Post
    Were not hanging balls from the tow hitch, its a subtle design to mimic that of a higher end car, not a race car or a riced car. When was the last time you saw a GP that was raised two feet? just trying to add a little flare from an otherwise fairly plain car, not go mock-two and look like a tool doing it.
  17. #17 Re: 4th Brake Light (Under Decklid)
    Ugh always a hater among us LOL, I think its looks sick and for sure is different I havent seen any GP with that so
  18. #18 Re: 4th Brake Light (Under Decklid)
    Jun 2010
    Illinois.
    Nooo no no. I'm not hating. I'm just saying it's not my thing. Kudos to you though on wiring. I suck balls at that ****...
  19. #19 Re: 4th Brake Light (Under Decklid)
    Meh, its not too bad but thanks! Any ideas on what might be your thing? Im always interested in new ideas. I'm thinking about mounting my two amplifiers on the trunk lid, wanted to save space in the trunk and do something a bit different, what are your thoughts?
  20. #20 Re: 4th Brake Light (Under Decklid)
    Jun 2010
    Illinois.
    That would be ****ing brilliant. The only thing to keep into consideration is wiring that can adjust to the constant opening and closing of the lid...
    It would be perfect to find coiled wires for amps, like a radar detector power cable. Haha.
  1. Shaved Decklid Lock...
    By Iron Indian in forum Visual/Body Modifications
    Last Post: 07-18-2008, 10:03 AM
  2. KVR big brake kit
    By robahr24 in forum Brakes/Suspension/Chassis
    Last Post: 07-06-2008, 07:00 PM
  3. parking brake light???
    By kingd44 in forum General Tech Discussion
    Last Post: 02-20-2008, 11:38 PM
  4. Head Light/Tail Light Covers
    By datApocalypse in forum Visual/Body Modifications
    Last Post: 01-30-2008, 11:38 PM
