Thread: Raised Spoiler - Drainage Fix [*]
Page 1 of 5 123 ... LastLast
Results 1 to 20 of 92
  1. #1 Raised Spoiler - Drainage Fix [*]
    GT Level Member drunknmunky's Avatar
    McDonough/Warner Robins, GA
    This writeup on Raising your spoiler for water drainage has been added to the How To section and can be found Here
    Comments/Questions feel free to post...
  2. #2 Re: Raised Spoiler - Drainage Fix
    Oklahoma
    Yeah, this is a good one to have here. I, fortunately, ran across this mod within weeks of getting my GP. Unfortunately there is a slight amount of paint damage from vibration and rubbing more than anything, but I got some rubber spacers that have worked flawlessly.
  3. #3 Re: Raised Spoiler - Drainage Fix
    yea i think everyone needs to do this. under the spoiler is really a good place for rust to start... and before u know it, u need a new deck lid.
    I just get alot of information from the sites and figured i'd tried and give back somehow. I know many folks know this mod, but some may not, or some may have forgotten about it... so its kinda a reminder for those.
  4. #4 Re: Raised Spoiler - Drainage Fix
    Oklahoma
    Im glad you posted it because I was one that had forgotten about it and I agree, we have new owners coming in that will need to know about this.
  5. #5 Re: Raised Spoiler - Drainage Fix
    yea i got mine like 8 years after build, and it wasnt really that bad... but i have seen pics of worse damage. mine has always been a GA car, so im sure in other areas of the world, rust and paint damage is probably really bad...
  6. #6 Re: Raised Spoiler - Drainage Fix
    GT Level Member BackInBlack's Avatar
    Vermont
    Toilet tank bolt washers work GREAT for this. Apply silicone GREASE to each side and it helps with the waterproofing without damaging anything or becoming permanent. Also, be sure the low spots of the wing have the 1/8" holes drilled in them to drain the water that inevitably finds it way inside.
    The GPs are long gone...
  7. #7 Re: Raised Spoiler - Drainage Fix
    TDCRacing
    Guest
    Good job brandon!!
  8. #8 Re: Raised Spoiler - Drainage Fix
    PA
    Quote Originally Posted by BackInBlack View Post
    This is what I did. I found them at lowes in the plumbing section. And they were already black, perfect for me.
    And since I had some rust around my holes, the surface was a little rough. So the silicone worked perfectly. Seals up great!
    2001 GSE
  9. #9 Re: Raised Spoiler - Drainage Fix
    GTP Level Member VinnieGTP's Avatar
    Las Cruces, NM
    I used these:
    Image: ACE TRADING BHDW 4 01-3028-505 "ACE" WALL DOOR STOP (pack of 5)
    I just used a razorblade to carefully cut the raised portion leaving only a large white, self adhesive, washer.
    Hard to see here. Im not at home for a couple weeks but I'll try to find a better pic:
    http://www.clubgp.com/owners/pics/5240.jpg
  10. #10 Re: Raised Spoiler - Drainage Fix
    ^ i want 2 see ur spoiler really bad w/ that big of a "door stop" but your link don't work 4 me?
  11. #11 Re: Raised Spoiler - Drainage Fix
    Las Cruces, NM
    It's not that big after you cut it down:
    ClubGP: Member List
    Not sure why the pic isn't working. Just click on it from the above link. It's dark, I know.
    Partial shot:
  12. #12 Re: Raised Spoiler - Drainage Fix
    not bad vinnie... another good idea of something to use... and brian, also a good suggestion...
  13. #13 Re: Raised Spoiler - Drainage Fix
    Las Cruces, NM
    Thanks, I couldnt find white washers and those just came to mind.
  14. #14 Re: Raised Spoiler - Drainage Fix
    GTX Level Member stlmo_gtp's Avatar
    St. Louis
    good write up i am about to go find out what 10 years of build up looks like
  15. #15 Re: Raised Spoiler - Drainage Fix
    stlmo_gtp - good luck, post pics of the destruction and before an after so others can see what we saw haha
  16. #16 Re: Raised Spoiler - Drainage Fix
    St. Louis
    i will be sure to post some pics of it during the weekend i am sure that it won't be pretty,10 years of stuff under there who knows what you will find
  17. #17 Re: Raised Spoiler - Drainage Fix
    u may find haffo's body!!! haha best of luck!
  18. #18 Re: Raised Spoiler - Drainage Fix
    sweet made it to sticky status! u guys rock! hope it helps plenty of people!
  19. #19 Re: Raised Spoiler - Drainage Fix
    sw suburbs Cleveland, Ohio
    LOL- I just went out and did this today- thanks!!!!!!!!!!!!!!!
  20. #20 Re: Raised Spoiler - Drainage Fix
    how bad was it? did u get pics?
    glad this could help you!!!
  1. my new hood and spoiler!
    By kyle99gtp in forum General Tech Discussion
    Last Post: 04-18-2008, 10:47 PM
  2. aftermarket spoiler at junkyard...
    By fst in forum Off Topic Discussion
    Last Post: 03-03-2008, 09:31 PM
