Thread: Raised Spoiler - Drainage Fix [*]
Page 3 of 5 FirstFirst 12345 LastLast
Results 41 to 60 of 92
  1. #1 Re: Raised Spoiler - Drainage Fix []
    GT Level Member Egleone6's Avatar
    Springfield, Illinois, United States
    Quote Originally Posted by drunknmunky View Post
    and what do you mean u used super glue on the bolts?
    I used the super glue to attach the two washers and then a little and the bottom of the washer so it would stay put while I put the spoiler on.
    I washed the car today and to see if it leaked, I attached a piece of paper towel on each bolt and taped that to the underside of the trunk. NO WATER, YET.......
    If my pics are not working, please email me, I may have moved the pics on a different page on Photobucket. Thanks
  2. #2 Re: Raised Spoiler - Drainage Fix []
    May 2008
    McHenry IL
    i want to do this to my 99 GTP now doesnt seem that hard to do.. what if i got like a inch or 1 and a 1/2 spacers would that work? idk with it raised a bit more then normal may look cooler idk. what do youll think.????.
  3. #3 Re: Raised Spoiler - Drainage Fix []
    Quote Originally Posted by GTPJOE90 View Post
    You would have to use a different bolt. The one you get stock is too small to use.
  4. #4 Re: Raised Spoiler - Drainage Fix []
    ^just try it! and if it don't look good, get smaller spacers.
    not 2 much money invested 2 change it.
  5. #5 Re: Raised Spoiler - Drainage Fix []
    SE Level Member Randy_W's Avatar
    May 2008
    sALISBURY, md
    I take it this is for the '03 and back cars? mine on my '05 is already raised.
  6. #6 Re: Raised Spoiler - Drainage Fix []
    May 2008
    McHenry IL
    yeah i got a 99 GTP Randy so would it be a big deal and hard to get the same screws but just longer at like home depot or something?
  7. #7 Re: Raised Spoiler - Drainage Fix [*]
    May 2008
    McHenry IL
    just finished mine looks good enough gap between the spoiler and lid so water is easy to flow threw now! =] thanks and this is def sticky worthy looks nicer also i lifted it up a bit more then a washer =] i used 2 washers and a flat metal locktight.
  8. #8 Re: Raised Spoiler - Drainage Fix [*]
    GT Level Member drunknmunky's Avatar
    McDonough/Warner Robins, GA
    glad it worked for you!!! hope it helps many others...
  9. #9 Re: Raised Spoiler - Drainage Fix [*]
    May 2008
    McHenry IL
    yeah its worked well only thing is i was just wondering with my steel washers and stuff will it rust out and screw my paint up or anything???
  10. #10 Re: Raised Spoiler - Drainage Fix [*]
    out i wouldnt ahve used metal... um... some metals will rust... but id be more concerned with vibrations scratching the paint then rust from where paint may be scratched away? but dont know? if you siliconed around the washes and all then water shouldnt get in there tho?
  11. #11 Re: Raised Spoiler - Drainage Fix [*]
    May 2008
    McHenry IL
    yea thats what im thinking im sure she'll be fine =] my sub amd amp below doesnt help with the vibration THANKS AGAIN DEF STICKY WORTHY!
  12. #12 Re: Raised Spoiler - Drainage Fix [*]
    again no problem, glad to help.. .just hope many others can find use of the post
  13. #13 Re: Raised Spoiler - Drainage Fix [*]
    May 2008
    McHenry IL
    yup i hear ya munkey
  14. #14 Re: Raised Spoiler - Drainage Fix [*]
    Jersey
    did my spolier raise with 1/16'' rubber spacers, great idea! worked great
  15. #15 Re: Raised Spoiler - Drainage Fix [*]
    glad to hear it... was there bad damage under there? got any before and after pics?
  16. #16 Re: Raised Spoiler - Drainage Fix [*]
    Jersey
    Na didnt take any pics, my bad.. but there was some surface rust and some serious dirt plus those outlines, which i couldnt get off... it didnt help the old lady that used to have my car never washed it..
  17. #17 Re: Raised Spoiler - Drainage Fix [*]
    yea that was what i was faced with, lack of washing causing trapped dirt and rust
  18. #18 Re: Raised Spoiler - Drainage Fix [*]
    May 2008
    McHenry IL
    mine had no rust i was shocked but i did have the outline of the spoiler haha =]
  19. #19 Re: Raised Spoiler - Drainage Fix [*]
    SE Level Member HOPPY's Avatar
    Jul 2008
    Howell, MI
    just pulled off the tail the other day and found total mayhem but I fixed it up alittle bit and took to progress photos also so here it goes...
    Sanded...
    [img=http://img526.imageshack.us/img526/3185/picturesofcar030rl2.th.jpg]
    Painted... cant tell but the paint area is darker then the rest of the car but its mainly under the tail and unnoticeable...
    And lifted... the rubber washers I used were red and are not visible at all, great Idea Drunk.
  20. #20 Re: Raised Spoiler - Drainage Fix [*]
    May 2008
    McHenry IL
    ??? just make the pics actually show up lol. HAY your that kid on myspace i accepted as my buddy u asked me about the FWI lol WHATS UP?
  1. my new hood and spoiler!
    By kyle99gtp in forum General Tech Discussion
    Last Post: 04-18-2008, 10:47 PM
  2. aftermarket spoiler at junkyard...
    By fst in forum Off Topic Discussion
    Last Post: 03-03-2008, 09:31 PM
