Thread: HID Fog Light Install
Results 1 to 13 of 13
  1. #1 HID Fog Light Install
    Jul 2010
    Coquitlam,BC,Canada
    I finally got my fog lights; Piaa 510SMR's, Piaa lens protectors, and Beamers H3 HID bulbs. Here is the install.....
    Pile 'o parts.
    Drilled larger holes in the Piaa housings to clear the HID bulbs.
    HID bulbs in the new lenses.
    The "unclear" stock lamps.
    Side shots of the stock lamps.
    Lens removed from stock lamp housing.
    Piaa housing urethaned to the stock housing. Not pretty, but it works.
    Lens protectors stuck to the Piaa lenses.
    880 bulb sacrificed and turned into a plug for the HID harness.
    Relay base swapped to one with a mounting tab.
    Ballasts and ignitors mounted.
    Relay mounted.
    Lights ready for install.
    Fog lights back in place.
    And now some "lights on" action.....
    Fog lights.
    Low beams.
    Hi beams.
    Not sure why the fogs look so blue in the picture, but they are the same colour as the headlights in real life.
    To see all the pics and some more detail, go here to my personal web-page.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  2. #2 Re: HID Fog Light Install
    that is awesome.
    how much are the fogs?
  3. #3 Re: HID Fog Light Install
    Waukesha, WI
    legit
    RayRay
    92 Turbo miata
    71 bagged lemans wagon
    02 lexus is300
  4. #4 Re: HID Fog Light Install
    Jul 2010
    Coquitlam,BC,Canada
    that is awesome.
    Quote Originally Posted by redlinepontiac View Post
    legit
    Thanks guys. These things are awesome; it is so nice to have some good light for a change. I'll be ordering up some new headlights and clear corners next month. Then I'll really be legit.
    Retail is about $300. I see them online for $200-250 ish.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  5. #5 Re: HID Fog Light Install
    holy crap, 200 bucks, i think i'll find a different brand then haha
  6. #6 Re: HID Fog Light Install
    Jul 2010
    Coquitlam,BC,Canada
    I hear ya. They are glass lenses, which means the best possible light.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  7. #7 Re: HID Fog Light Install
    Jun 2011
    Detroit, MI
    Quote Originally Posted by Bronco Boy View Post
    No lenses would be best possible light.
    iLoveSpade
  8. #8 Re: HID Fog Light Install
    Jul 2010
    Coquitlam,BC,Canada
    Quote Originally Posted by Hippo Machine View Post
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  9. #9 Re: HID Fog Light Install
    West Side Michigan
    Looks good bro, Wish they were a tad bit bigger and filled up the hole more, but they are cool. I put weather stripping around mine to keep them from the slight bounce they had, they also nestled in there pretty nicely too, and show no gap.
    Just make sure you put the clear lens protector on to protect from debris..
    Rocks + Glass =
  10. #10 Re: HID Fog Light Install
    Jul 2010
    Coquitlam,BC,Canada
    Quote Originally Posted by nawarkk View Post
    Thanks. I was thinking the same way, but I like how they turned out; no vibrations (so far).
    Rocks + Glass =
    Yup. Pic #10, good to get pelted with rocks.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  11. #11 Re: HID Fog Light Install
    Sep 2011
    Sioux City, IA
    I really like how those mount up!!! Alot better than factory too! Check these out too, Blazer Fog Light Stage III Kit - Complete Retrofit Kits from The Retrofit Source Inc They are a little cheaper, but they are a projector instead and they are fully sealed too. Granted they dont bolt up like yours did after you used the old housing, but they do come with brackets.
    Have you guys thought about retrofitting projectors into the stock head lights?? I am going to do that to mine here this winter.
  12. #12 Re: HID Fog Light Install
    Bunnell, FL
    nice got a write up for 04+ fogs into a 97-03?
    I'm a Sex Offender
  13. #13 Re: HID Fog Light Install
    Jul 2010
    Coquitlam,BC,Canada
    Quote Originally Posted by gtpfergie View Post
    Aren't there about 80 threads on this?
    Quote Originally Posted by z3r0 View Post
    Nope. I did see one on the board here a while back.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  1. Replies: 18
    Last Post: 03-24-2011, 02:07 AM
  2. Hid fog light install
    By blortz in forum Visual/Body Modifications
    Last Post: 03-14-2011, 01:20 AM
  3. HID light install
    By BennyG in forum General Tech Discussion
    Last Post: 07-21-2010, 08:12 AM
  4. Replies: 16
    Last Post: 01-23-2010, 09:43 AM
  5. 4th Brake Light install, thanks DrunkNMonkey!!
    By GeddyLee in forum Visual/Body Modifications
    Last Post: 08-11-2008, 09:55 AM
