LOL thats what i was trying to say. But if there was nothing there stopping it, then yes it would go in and just " drop off"
goin to replace both elbows tomorrow, I have changed the top elbow so many times now its a 15 min job lol I have the aluminum ones now so those are going in and I did pick up an extra set just incase something goofy happens.
Is it a common problem to have the coolant elbow o-ring fail but the intake gaskets still be good? I pressured the coolant system up and found one of the elbows was not holding pressure. I have no coolant in my exhaust or oil. It seems like i need to replace the coolant elbows, but it seems too simple. I have an 05 which from my reading is hit or miss on getting the plastic intake gaskets.
Coolant elbows and intake gaskets are two seperate issues.
I don't have a replacable bottom elbow, its molded into the exchange unit so I just replaced the seal, I put the metal one on top though and that did the trick, no more leak.
Yes.. they are.
damnit...
so I got the new mounts in and went and did a WOT run with wife, and she said HOLY **** this car goes pretty good... then I thought my dash lights went dim, and i couldnt figure it out. I was about a mile from the house. I headed home and the temp went up to 75% (no numbers on the buick). CRAP!!! limped home. didnt go any higher. pulled in and a cloud of "smoke/steam" passed. DAMN.
I knew right where to look. SURE ENOUGH. it split.
Ill be rushing to do this tomorrow after work as we are supposed to take it for a up north trip saturday morning... I guess better a mile from home than half way to da UP eh?!
Took vacation Thursday, Friday, had Saturday & Sunday off. Got to work this morning, smelled coolant, heard car pissing, split elbow. Dam the luck, couldn't happen over my vacation time, yay troll car. So glad you made this Bill, get to dive in after work today.
What y'all thought on metal elbows
im willing to bet they still fail at the o rings. like the plastic set i had.
you also just stuck 2 different metal types together. more problems to come? only time will tell.
Mines been on for almost 2 years, there both aluminum
I also had them on for two years and did the intake gasket also metal this summer and reused them have had no leaks
Funny, I still have my original plastic elbows on my 99 GP GT with 98k miles!
I am going to finally do my LIM gasket and elbows this spring including a full maintenance
service including all heater/radiator hose, thermostate/gasket, valve cover gaskets/grommets
and antifreeze.
I'd run a colder thermostat, and use the aluminum coolant elbows if you are using the plastic ones
okay so I have a 98 GP and I read your special note about the Alternator bracket having a metal casted assembly. But the way you describe how to pull it out is a bit confusing. Also, I thought it was the tensioner bracket that has the metal casted elbow? Are you saying the alternator has a metal cast plus the tensioner bracket?
Other than that, everything else sounds good.
those parts listed are the alt bracket/ tensioner/ coolant elbow if a 97 or 98.
the 97-98, you take the alt off, break the upper elbow so it has no fight. remove the 3 bolts and coolant hoses off the bracket, then pull the bracket to the fender while wiggling the bracket a little bit as your pulling on it.
a 97-98 bracket, see the lower cast elbow on the bottle left of the part? thats the cast elbow.
http://i33.photobucket.com/albums/d6...6/DSC03017.jpg
