Thread: How to pull an engine: BillBoost Style
Results 1 to 20 of 105
  1. #1 Re: How to pull an engine: BillBoost Style
    Rear knock sensor should be attached to the rear of the ps pump or hanging out close by. There's a connector about 12-18 from the knock sensor that they located right by the wheel well to make it easy. Problem is..most don't realize it's on the back of the ps pump and el ripppo
  2. #2 Re: How to pull an engine: BillBoost Style
    Mar 2015
    USA
    Two-Ton Hydraulic Engine Hoist: A handy tool for testing the tensile strength of ground straps, wiring harnesses, hydraulic clutch lines you may have forgotten to disconnect.
  1. Test BillBoost
    By BillBoost37 in forum Off Topic Discussion
    Last Post: 07-26-2011, 12:38 PM
  2. Thanks to Bio, Billboost, 01GTP, Reptile, Blue and others
    By Silver GTP in forum Shops and Community Heroes
    Last Post: 09-09-2010, 10:11 AM
  3. New headers after engine pull lots of noise
    By machinegunsquid in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-21-2010, 11:37 PM
  4. Engine and Trans pull... SAME TIME?
    By nathangartz in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-14-2009, 09:40 PM
  5. pull engine?????
    By kingd44 in forum Off Topic Discussion
    Last Post: 08-10-2008, 09:12 PM
