So you may notice that your car has excessive body roll or your sway bar has broken and it probably looks like this
You should have all this to completely put it together
Now the first thing to do is undo the links or if they are seized up, cut 'em off!! They are a 13mm socket
Then undo these (15mm) the drivers side has gas and brake lines in the way, so you may want to get a flex socket joint thing
Pull out the bar and we have this, because race car
Now put the new bar in, it takes some wiggling and patience and maybe turn the wheels so it falls into place
Put the links together in this order
Now re-bolt the bushings and bracket back into place (15mm again) and then tighten the links down so there is about 1.25-1.5" of threads showing (13mm)
You're all done now, congratulations
