Thread: How to get PCV to work instead of valve cover breather!
Results 1 to 20 of 122
  1. #1 Re: How to get PCV to work instead of valve cover breather!
    Mercer, Pa
    The air flows into the front valve cover and is sucked up through the Intercooler and into supercharger under the PVC valve. Note the PVC valve is in supercharger under black cover plate. There is no need for a oil catch can on the front hose and no place to put one inline on the rear port. This setup won't suck in more oil then the factory setup, if anything it will suck less.
  2. #2 Re: How to get PCV to work instead of valve cover breather!
    Vancouver, WA
    So I have a Gen V, L32, L67 TB, L67 EVAP, and older WBS IC. So if I do the mod in this thread that gets the front running properly but not the back. All I have on the back is a breather off the SC nipple. What would I need to do to get the rear PCV working also?
    Slowest 'Cooled Gen V ever
  1. Valve Cover
    By kcfalcon2000 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-27-2011, 10:24 AM
  2. Valve cover Breather
    By klj5022 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-14-2011, 06:27 PM
  3. Valve Breather Modification And Repair [*]
    By nemesis in forum How To Write-Ups/Tech Tips
    Last Post: 12-21-2008, 07:47 PM
  4. Valve Cover
    By justaV6 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-25-2008, 09:15 PM
