Thread: How do I find a CAM for my car [*]
Results 1 to 10 of 10
03GPScottyd How do I find a CAM for my... 06-17-2008, 11:57 AM
03GPScottyd Re: How do I find a CAM for... 06-17-2008, 12:00 PM
black.gtp Re: How do I find a CAM for... 06-17-2008, 03:56 PM
e56505 Re: How do I find a CAM for... 08-22-2008, 01:28 PM
offroadfury6 Re: How do I find a CAM for... 08-24-2008, 09:32 AM
blueguy Re: How do I find a CAM for... 08-24-2008, 11:13 PM
offroadfury6 Re: How do I find a CAM for... 08-24-2008, 11:36 PM
blueguy Re: How do I find a CAM for... 08-25-2008, 03:54 AM
offroadfury6 Re: How do I find a CAM for... 08-25-2008, 03:54 AM
blueguy Re: How do I find a CAM for... 08-25-2008, 05:59 AM
  1. #1 Re: How do I find a CAM for my car
    Louisville, KY
    Do I Need a CASE Learn?
    You DO need to perform the Crankshaft Variation Learn procedure if you physically install a new PCM, replace the crankshaft, camshaft, timing chain, crankshaft position sensor or balancer.
    You DO NOT need to perform the Crankshaft Variation Learn procedure if you have new code flashed into your current PCM.
    The crankshaft position system variation learning feature calculates the reference period errors that are caused by slight tolerance variations in the crankshaft, the crankshaft balancer interrupter rings, and the crankshaft position sensor hall effect switches. The calculated error allows the PCM to accurately compensate for reference period variations. This enhances the ability of the PCM to detect misfire events during a wider range of engine speed and load conditions.
    The crankshaft position system variation values are stored in the PCM non-volatile memory after a learn procedure has been performed. If the crankshaft position system variation values are not stored in the PCM, DTC P1336 will set. The learn procedure is required after the following service procedures have been performed:
    PCM replacement
    Engine replacement
    Crankshaft replacement
    Crankshaft balancer replacement
    Crankshaft position sensor replacement
    Any engine repair which disturbs the crankshaft or the harmonic balancer to crankshaft position sensor relationship.
    97's don't need a case learn with a PCM swap, just swap the Knock Modules and you're all set.
    Service Manuals for 1997 GTP
    The crankshaft position system variation compensating values are stored in the PCM non-volatile memory after a learn procedure has been performed. If the actual crankshaft position variation is no within the crankshaft position system variation compensating values stored in the PCM, DTC P0300 may set (refer to Diagnostic Aids for DTC P0300).
    The crankshaft position system variation learn procedure must be performed when replacing the PCM to clear DTC P1336. The crankshaft position system variation learn procedure is also required when the following service procedures have been performed, regardless of whether or not DTC P1336 is set:
    PCM replacement.
    Engine replacement.
    Crankshaft replacement.
    Crankshaft balancer replacement.
    Crankshaft position sensor replacement.
    Any engine repair(s) which disturbs crankshaft/harmonic balancer to crankshaft position sensor relationship
    Want to know more
    Do I Need a CASE Learn? - 3800Pro.com Forum
    My Cardomain
  2. #2 Re: How do I find a CAM for my car
    SE Level Member black.gtp's Avatar
    Apr 2008
    Indiana
    I have the prj LL cam it has a real nice lobe and its very vavletrain friendly and built for stock heads contact sales@prjperfomance.com he can answer some of your questions I have a link to my exhaust clip in my sig
    PRJ Built enough said!!!!
    www.prjperformance.com
  3. #3 Re: How do I find a CAM for my car
    Aug 2008
    michigan
    dude that thing sounds like a frickin harley, nice job on that!wow
  1. tryin to find a thread
    By johnnyj773 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-21-2008, 01:56 PM
  2. For all your hard to find car part needs!
    By Reptile in forum Off Topic Discussion
    Last Post: 05-09-2008, 09:13 AM
  3. can find a certain thread...
    By gp4u2c in forum Off Topic Discussion
    Last Post: 01-20-2008, 01:54 AM
  4. Find all your own posts
    By TooMch in forum Forum Bugs/Suggestions
    Last Post: 01-08-2008, 05:31 AM
cam, car
