Thread: How To Remove '04+ Rear Deck (speakers)
Results 1 to 20 of 21
  1. #1 How To Remove '04+ Rear Deck (speakers)
    Pennsylvania
    This article will describe how to remove the rear deck on a 2004 and newer Grand Prix. This is how you would access the rear speakers, amp, compass, or seat belt assemblies for replacement. If you're a real tricky fella, you may want to try skipping steps 3,4, and 6 to see if you can work that plastic bolt out without removing the seat frame.
    Recommended tools:
    *15mm wrench
    *18mm deep socket
    *10mm socket
    *flat head screwdriver
    *chain-nose pliers
    *yelling
    1. There's two T-shaped handles under each seat where your balls would sit. Pull those. Harder. Your rear seat will pop out. Remove it.
    **Pro Tip: You'll find approximately $0.82 and an entire box of crackers. Keep the money, the crackers can be discarded as they are a 30,000 mile part and have been dragging down your 1/4 mile times.
    2. There's a 15mm bolt on the door-side edge of the hinge on both seat panels. You'll have to squeeze it past some cushion. Jiggle your seat panels out.
    3. The bottom of the seat frame is held down with three 18mm nuts and two 18mm bolts. The bolts will require your Man Hand for removal.
    4. Remove the seat belts from the bottom of the frame with some serious jiggling. Might help to use a flat head screwdriver or loud yelling.
    5. The top of the frame is held on by four 10mm bolts. Piece of cake.
    6. Pop out the frame, being careful not to break the plastic portion at the top.
    7. Fold all the seatbelts through the slits in the upper deck so that they lay behind it.
    8. The carpet-coated cardboard deck is held in by two big plastic railroad spikes right under the seatbelt holes you need to pull out. Yell at them, too.
    9. Carefully remove the deck. It may help to push upward on the middle to get it past the pillars. Try not to crack your speaker grills - they're ironically fragile. Also, don't lean on the compass thing in front of your amp.
    **Pro Tip: Have a vacuum cleaner handy for the three hundred dead bees you find.
    10. Your speakers are held in by two plastic tabs each. You can figure that out for yourself if you got this far.
    11. Use a flat head screwdriver, roofing nail, or prison shank to un-clip the speaker wires from the speaker.
    12. Swap speakers.
    13. *****TEST SPEAKERS BEFORE RE-ASSEMBLY OF SEATS******
    14. Re-assemble seats.
  2. #2 Re: How To Remove '04+ Rear Deck (speakers)
    Utah
    This was a very helpful and amusing post! Thank you very much.
  3. #3 Re: How To Remove '04+ Rear Deck (speakers)
    GT Level Member dengnath's Avatar
    i did it without removing the seat at all... alot less of a pain in the ass
  4. #4 Re: How To Remove '04+ Rear Deck (speakers)
    Pennsylvania
    Quote Originally Posted by dengnath View Post
    Would be nice if you provided a write-up, then... lol
  5. #5 Re: How To Remove '04+ Rear Deck (speakers)
    i cant take pics now.... i have done it lol.....
    i folded the seats down
    then i lossened the 4 bolts that are in the center of that plastic brace
    then i pulled forward on the two outside peices of seat to get that clip undone... i ended up breaking them but they r uneccessary anyway.
    then i just wobble the edges out.... it worked out pretty easy.
  6. #6 Re: How To Remove '04+ Rear Deck (speakers)
    Apr 2011
    Springfield
    Does anyone know where I can find the write up for the front door panel removal/speaker install?
  7. #7 Re: How To Remove '04+ Rear Deck (speakers)
    SE Level Member Tuned 2 F's Avatar
    Jul 2010
    Cburg VA
    I can't thank you enough for posting this tutorial.
    I was very iffy as to how I should remove the rear deck, it just won't budge even after I removed the seats. For some reason there is no thick plastic bolt in my car. Still haven't got it out but I'm going to try again tomorrow.
    Thats wierd that the inside of your car is white when the outside is that stealth grey metallic or whatever they call it. Mine has the same exterior color and is the same color on the inside.
  8. #8 Re: How To Remove '04+ Rear Deck (speakers)
    Pennsylvania
    I was working on a different car. My blue '06 is just a wee base model without the Monsoon system... so the rear speakers will never get blown out and never need replacement
  9. #9 Re: How To Remove '04+ Rear Deck (speakers)
    London Ont, Canada
    Im gonna be replacing my stockers with some JBL Gto's today i think.. I will see what I can do without having to take the seats out, otherwise thanks for the helpful info! reminds me of my 99 and how much of a pain that was lol
  10. #10 Re: How To Remove '04+ Rear Deck (speakers)
    you can do it without taking the seats out.... i did = )
  11. #11 Re: How To Remove '04+ Rear Deck (speakers)
    London Ont, Canada
    I should add... without breaking anything too lol
    seems to be a sunday project
  12. #12 Re: How To Remove '04+ Rear Deck (speakers)
    i didnt break anything.... except for those little plastic plugs, i didnt put those back in but those dont matter anyways.
  13. #13 Re: How To Remove '04+ Rear Deck (speakers)
    Pennsylvania
    plastic plugs
    Auto parts store's got 'em for like $3 for a handful.
  14. #14 Re: How To Remove '04+ Rear Deck (speakers)
    **thick plastic bolts**
  15. #15 Re: How To Remove '04+ Rear Deck (speakers)
    ya they r useless anyway
  16. #16 Re: How To Remove '04+ Rear Deck (speakers)
    Northeast Ohio
    dengnath did you put in factory or after market speakers and was it on a monsoon system
  17. #17 Re: How To Remove '04+ Rear Deck (speakers)
    aftermarket speakers.... i got them free with my best buy rewards.... they are polk audio loundspeakers.
  18. #18 Re: How To Remove '04+ Rear Deck (speakers)
    Northeast Ohio
    how did you wire them up using the existing wires from the old speaker or before the amp?
  19. #19 Re: How To Remove '04+ Rear Deck (speakers)
    London Ont, Canada
    Quote Originally Posted by 06PONTGP View Post
    when i put my JBL's in the back, i used the factory quick connect and soldered it onto the speakers that way if i need to remove them i can easily
  20. #20 Re: How To Remove '04+ Rear Deck (speakers)
    Northeast Ohio
    thanks for the info i got 2 rockford fosgate punch series i think my amp is messed up since i only had highs on my rear speakers but anyways i wired them up to the new speakers just like they were to the factory
  1. best speakers for rear deck 07 gp gt
    By gmoney25 in forum Audio, Security & Visual Electronics
    Last Post: 08-12-2010, 01:55 PM
  2. reomve or keep 4" speakers in rear deck?
    By Slueth66 in forum Audio, Security & Visual Electronics
    Last Post: 03-17-2010, 10:54 PM
  3. please help! how to remove rear speakers to put new ones!
    By gpgtp99 in forum Audio, Security & Visual Electronics
    Last Post: 12-13-2009, 05:18 PM
  4. 4" Rear Deck Speakers
    By Aceoage in forum Audio, Security & Visual Electronics
    Last Post: 09-06-2008, 09:04 AM
  5. 4" speakers in the rear deck....
    By halfwit in forum Audio, Security & Visual Electronics
    Last Post: 07-02-2008, 05:40 AM
