Thread: How-to add LED's & have them pulse from amplifier
Results 1 to 6 of 6
mousemonster1232 How-to add LED's & have them... 02-05-2011, 12:02 AM
Koniig Re: How-to add LED's & have... 02-05-2011, 01:00 AM
DreadMcLaren Re: How-to add LED's & have... 02-05-2011, 01:02 AM
dpzelenak Re: How-to add LED's & have... 02-05-2011, 01:51 PM
mousemonster1232 Re: How-to add LED's & have... 02-05-2011, 05:56 PM
dpzelenak Re: How-to add LED's & have... 03-17-2011, 06:46 PM
  1. #1 Re: How-to add LED's & have them pulse from amplifier
    thanks much help, but i got two questions,,,will it still work if you have a single channel amp?,,,and can you us a led strip(store bought) in stead of making a box to put them in?
  2. #2 Re: How-to add LED's & have them pulse from amplifier
    SE Level Member mousemonster1232's Avatar
    Surprise, AZ
    Yes it will work with a single channel amp. The port can be used when powering it. I have a 2ch amp powering two subs, and I have it twisted in with the coupler on the sub.
    And as for the LED strip, I am not to positive, I think it would be blown as most factory made are for 12v power source max. As the subs have varying (usually between 1-27v), it would most likely blow out the LEDs. Give it a try though! Take a look at the packaging and see what it says.
  1. P0753, P0758, P1860, 1-2 and 2-3 shift solenoid and TCC pulse width modulator errors
    By STOCKTA in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-29-2013, 08:36 AM
  2. Wiper Pulse board or Multi function control
    By JGN in forum General Tech Discussion
    Last Post: 06-09-2010, 02:55 PM
  3. Help on choosing new amplifier
    By GAFF in forum Audio, Security & Visual Electronics
    Last Post: 03-04-2010, 09:39 AM
  4. Pulstar pulse plugs?
    By a98gtp4u in forum General Tech Discussion
    Last Post: 09-20-2009, 08:47 PM
