Thread: How To: Install 1.8 Roller Rockers on L67
Results 21 to 40 of 60
Threaded View
Mitchstrp How To: Install 1.8 Roller... 01-09-2011, 03:24 AM
blueguy Re: How To: Install 1.8... 01-09-2011, 11:27 AM
Mitchstrp Re: How To: Install 1.8... 01-09-2011, 11:33 AM
blueguy Re: How To: Install 1.8... 01-09-2011, 11:35 AM
Mitchstrp Re: How To: Install 1.8... 01-09-2011, 11:39 AM
matt5112 Re: How To: Install 1.8... 01-09-2011, 11:40 AM
Mitchstrp Re: How To: Install 1.8... 01-09-2011, 11:42 AM
DBGP Re: How To: Install 1.8... 01-10-2011, 12:38 AM
Mitchstrp Re: How To: Install 1.8... 01-10-2011, 12:20 PM
BillBoost37 Re: How To: Install 1.8... 01-10-2011, 12:54 PM
Mitchstrp Re: How To: Install 1.8... 01-10-2011, 12:58 PM
Dallasneon Re: How To: Install 1.8... 01-10-2011, 02:05 PM
Mitchstrp Re: How To: Install 1.8... 01-10-2011, 02:07 PM
Dallasneon Re: How To: Install 1.8... 01-10-2011, 02:14 PM
Mitchstrp Re: How To: Install 1.8... 01-10-2011, 02:19 PM
Dallasneon Re: How To: Install 1.8... 01-10-2011, 02:20 PM
Bio248 Re: How To: Install 1.8... 01-10-2011, 02:20 PM
Mitchstrp Re: How To: Install 1.8... 01-10-2011, 02:21 PM
BillBoost37 Re: How To: Install 1.8... 01-10-2011, 02:46 PM
Mitchstrp Re: How To: Install 1.8... 01-10-2011, 04:07 PM
Ricky21 Re: How To: Install 1.8... 01-10-2011, 04:26 PM
matt5112 Re: How To: Install 1.8... 01-10-2011, 04:28 PM
Mitchstrp Re: How To: Install 1.8... 01-10-2011, 04:30 PM
Ricky21 Re: How To: Install 1.8... 01-10-2011, 04:44 PM
Mitchstrp Re: How To: Install 1.8... 01-10-2011, 04:49 PM
Mitchstrp Re: How To: Install 1.8... 01-10-2011, 04:28 PM
cliffdawg Re: How To: Install 1.8... 01-10-2011, 04:37 PM
Mitchstrp Re: How To: Install 1.8... 01-10-2011, 04:38 PM
matt5112 Re: How To: Install 1.8... 01-10-2011, 04:52 PM
Silver GTP Re: How To: Install 1.8... 01-10-2011, 10:25 PM
Mitchstrp Re: How To: Install 1.8... 01-10-2011, 04:53 PM
matt5112 Re: How To: Install 1.8... 01-11-2011, 12:34 AM
Ricky21 Re: How To: Install 1.8... 01-11-2011, 01:53 AM
BillBoost37 Re: How To: Install 1.8... 01-11-2011, 06:33 AM
Mitchstrp Re: How To: Install 1.8... 01-11-2011, 12:44 PM
SDGTP99 Re: How To: Install 1.8... 01-24-2011, 09:09 PM
Silver GTP Re: How To: Install 1.8... 01-24-2011, 09:24 PM
Lacboi Re: How To: Install 1.8... 01-25-2011, 11:59 PM
matt5112 Re: How To: Install 1.8... 01-26-2011, 08:24 AM
nascartech Re: How To: Install 1.8... 02-12-2011, 01:22 AM
matt5112 Re: How To: Install 1.8... 02-12-2011, 12:15 PM
02 monte carlo ss Re: How To: Install 1.8... 02-12-2011, 01:01 PM
nascartech Re: How To: Install 1.8... 02-12-2011, 10:45 PM
real diehl Re: How To: Install 1.8... 02-12-2011, 10:53 PM
nascartech Re: How To: Install 1.8... 02-12-2011, 11:19 PM
02 monte carlo ss why would you have to upgrade... 02-13-2011, 12:00 PM
Pure2sin Re: How To: Install 1.8... 02-13-2011, 12:04 PM
02 monte carlo ss what retainers would i need ... 02-13-2011, 12:17 PM
01gpgt01 Re: How To: Install 1.8... 02-13-2011, 12:36 PM
02 monte carlo ss would you happen to know what... 02-13-2011, 12:44 PM
matt5112 Re: How To: Install 1.8... 02-13-2011, 06:02 PM
Pure2sin Re: How To: Install 1.8... 02-13-2011, 08:55 PM
02 monte carlo ss Re: How To: Install 1.8... 02-13-2011, 09:04 PM
GreyGhost Re: How To: Install 1.8... 03-30-2011, 03:23 PM
matt5112 Re: How To: Install 1.8... 03-30-2011, 05:28 PM
thunder71173 Re: How To: Install 1.8... 03-30-2011, 05:46 PM
matt5112 Re: How To: Install 1.8... 03-30-2011, 05:55 PM
thunder71173 Re: How To: Install 1.8... 03-30-2011, 06:20 PM
matt5112 Re: How To: Install 1.8... 03-30-2011, 07:18 PM
FriboRage Re: How To: Install 1.8... 05-09-2013, 02:22 PM
  1. #1 How To: Install 1.8 Roller Rockers on L67
    GT Level Member Mitchstrp's Avatar
    Missouri
    Tools you will need:
    7mm
    8mm
    10mm
    13mm
    15mm
    Hex socket
    engine assembly lube
    torque wrench
    roller rockers
    valve cover gaskets
    install kit
    Pop your hood, this is what you should see.
    first things first, disconnect the battery and remove all both the belts.
    second remove the ICM wire harness (under the coil packs) then start removing the s/c tensioner and idler pulley.
    After removing tensioner pulley there should be a long stud
    then above the tensioner there is a stud that has a ground on it, its the ICM ground, remove the stud.
    Then remove the stud where the tensioner pulley was.
    Next there is a stud that is held in by a 15 mm and you will need a very deep well socket it is located in between the tensioner and idler pulley.
    Once you have that last stud out. the entire bracket will just pull right out. Now you can access the front valve cover.
    Remove the bolts and gromets and pull out the valve cover.
    You should now be looking at something like this.
    Now with your 10mm remove all the old rockers and pushrods and the pedistal.
    Now install your Yella Terra (or other brand) pedistal with the logo facing you.
    Put the black spacers in place (they insert in the pedistal) then put the push rod where you removed the previous one then with the round side down place the rocker on the spacer and put a comp cam bolt in the rocker and hand tighten, once hand tightened adjust the rocker so that the roller tip is perfectly sitting on the spring and that the pushrod is under the proper side of the rocker.
    Do this for all the rockers and make sure that before you install the pushrods and roller rockers that they are well lubed with some engine assembly lube or soak them over night in cam assembly lube.
    When your done with the front this is what it should look like.
    Now onto the back!
    First ratchet the motor forward.
    Then remove the rear engine pull bracket with a 13 mm its only two bolts. After that remove the alternator bracket also a 13 mm i believe.
    Now your ready to get dirty. lol.
    Take off all the bolts and grommets then start remove the old rockers and pushrods, do the back just like you did the front.
    Thats all there is to it.
    final steps:
    Torque all of rocker bolts to 25 ft lbs then assemble just as you took apart. After you have reinstalled everything you can top off the front valve cover with a little oil.
    When you start the car you may get a low oil light but it should go off after a minute or so.
    If I missed anything feel free to let me know and ill add it.
    Hopes this helps
    1.8 RR's, Speed daddy headers, 180 stat, Open Cone, GBP tune, 3.5 pulley, and ported blower.
  1. roller rockers ?
    By bayareagtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-23-2008, 12:28 PM
  2. Roller Rockers
    By IndeedSS in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-19-2008, 05:49 PM
