Thread: Strut removal and installation
Results 1 to 20 of 28
Threaded View
  1. #4 Re: Strut removal and installation
    Charles City, IA
    Install the front in reverse order.
    When you are sliding the new strut up get the top studs threw the holes in the body and start one to hold the strut
    Then push the knuckle down and line up the lower part of the strut on the knuckle. A punch works great to line up the holes.
    Hammer the strut bolts back in and tighten up the nuts
    Then tighten up the top plate nuts.
    Reinstall tire.
    If your car drives straight after doing your struts I would not worry about an alignment. If you have any pulls then I would. You can save money on camber bolts by grinding the top hole in the bottom of the strut to widen it out a bolt width on each side of the whole. That will allow for enough movement to adjust the camber.
    Hope this write up helps you guys get more done on your own and save ya money. Feel free to pm me any ?s or post up in this thread. THanks NICK
    SMGPFC Two Nipple General
  1. Airbag removal and installation
    By mach158 in forum General Tech Discussion
    Last Post: 06-05-2011, 05:07 PM
  2. HId Installation??
    By silvermistgt2002 in forum Audio, Security & Visual Electronics
    Last Post: 12-25-2009, 08:29 PM
  3. HUD Installation- HELP???
    By lambokit in forum General Tech Discussion
    Last Post: 10-08-2009, 08:03 PM
  4. Monroe Quick Strut vs. KYB Strut Plus...definitive?
    By FRESCOLIO in forum Brakes/Suspension/Chassis
    Last Post: 09-30-2009, 05:27 PM
  5. Steering Wheel Removal & Installation
    By $03gp/gt$ in forum General Tech Discussion
    Last Post: 12-14-2008, 07:38 PM
