I think the problem would be (and maybe why it doesn't extend further) is that people running a cabin air filter would not be able to get to it. If you did make something, it would have to be easily removable to access the filter. Which would mean it would need some sort of seal or gasket where it attaches to the flange anyway. You'd just be trading one problematic part for another one IMO. Using an adhesive to attach the existing deflector will eliminate any problems anyone has with it for good.
BTW... I mentioned using RVT sealer to adhere it with. Another good option is a tube of windshield adhesive. That what mine is stuck on with since I have it readily available. It's black and you can see it in the pics where I pulled it part of the way off. Never use straight silicone on a painted surface. Make sure it is non-acidic silicone, or specially recommended for automotive use, if you do. Regular silicone will eventually cause the paint to peel away where ever it touches and will cause rust.
Another fine piece of information that deserves to be kept around in some form or fashion.BTW... I mentioned using RVT sealer to adhere it with. Another good option is a tube of windshield adhesive. That what mine is stuck on with since I have it readily available. It's black and you can see it in the pics where I pulled it part of the way off. Never use straight silicone on a painted surface. Make sure it is non-acidic silicone, or specially recommended for automotive use, if you do. Regular silicone will eventually cause the paint to peel away where ever it touches and will cause rust.
MAKE MORE MONEY TO FIX IT AT DEALER![]()
