Thanks for such a Great Posting, I had a rain water leak with lots of water showing up on the passengers side floorboard, was able to remove 2 small and one large plastic retainer and lift up the cowl and held it up with a small block of wood to allow access to the rubber seal without removing the plastic cowl or any wipers, found seal/deflector off and laying loose, cleaned metal and rubber and applied RTV Sealer then reinstalled the seal/deflector, let dry for 15 min. then reassembled, the next good rain will be the test, I have a lot of faith in this fixing the problem, Thanks again for posting without it I wouldn't have known what to look for or how to fix it.
