Thread: How to: LED turn signal mirrors
Page 3 of 3 FirstFirst 123
Results 41 to 51 of 51
  1. #41 Re: How to: LED turn signal mirrors
    To the top for burgundybullet
  2. #42 Re: How to: LED turn signal mirrors
    Banned
    Jan 2013
    Colorado
    those look awesome
  3. #43 Re: How to: LED turn signal mirrors
    GTP Level Member rperry435's Avatar
    Oct 2011
    MI
    The resurrection of this thread just Inspired me to go buy what I need after work tomorrow lol. Advance Auto has them. last time I used red I'll probably pick up some amber if they have them. I'll be sure to take a few pictures since I just spent another 10minutes searching through dropbox and no luck on a finished picture.
    Sent from my SPH-L710 using Tapatalk 2
    '04 CompG - 3.6MPS - 104s - FWI - TOGS - w/14"SlimFans - SLP RR' s - 180HF Stat - TEP SK - Aluminum Oil Pan - 4thGen ZZP Wires - LS7 Lifters - AeroForce - AEM WB - HPTuners - FBSS Air Ride
    ASE & State Certified Auto Electrical Tech
  4. #44 Re: How to: LED turn signal mirrors
    Jul 2011
    Chicago
    Here are the mirrors off mine before I sent it to GP heaven. The trans went out and I refused to put anymore money into it. There is no backing on the mirrors unless you have heated ones. They're the same as mirrored sunglasses. Mirrored on one side and see through on the back side. I used Bill's way and covered the back side, similar to his pods, so I wouldn't have a halo around the housing. Muth has downloadable instructions with the necessary wires to tap into. I plan on putting them in my convert this spring, or when it warms up.
  5. #45 Re: How to: LED turn signal mirrors
    I can't help that you GP guys never had a heated mirror feature. LOL originally the write up was for a Regal forum.
  6. #46 Re: How to: LED turn signal mirrors
    Jul 2010
    Coquitlam,BC,Canada
    Quote Originally Posted by rperry435 View Post
    When I did the led mirrors on my 04 gtp I took a set of the strip leds 3" long had 3 leds in each.
    I simply cut away some of the black plastic backing with a razor and without modifying the mirror Itself at all they shined through bright enough for me to be to satisfied. Here's a picture of them before I moved the leds to behind the mirror and from horIzontal to vertIcal. I can't seem to find a picture of the final.
    Sent from my Galaxy SIII on Tapatalk 2
    I was considering doing mine this way, but was concerned a bout the back-glow. I see my concerns were correct.
    FYI, this is how I did them on my last ride.....clicky clicky
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  7. #47 Re: How to: LED turn signal mirrors
    Oct 2011
    MI
    Like I said that shot was before I moved them to behind the mirror I never had any I'll side effects, I'm in the works of doing it again on this car.
    You used cheaper style LEDs and glued them in place, okay idea but in past experiences those style LEDs have quality issues and burn out often. The LEDs I use are usually smd sometimes cree depending on application. I also wasn't looking for an actual arrow just a 3 smd led strip at the vertical edge, to each his own
  8. #48 Re: How to: LED turn signal mirrors
    Oct 2011
    MI
    Totally didn't finish reading the end of your link, guess it confirmed what I thought would happen lol
    The set I did 2 years ago is still working great but the stripes are sealed.
  9. #49 Re: How to: LED turn signal mirrors
    Feb 2010
    TN
    having some confusion with the wireing can some one show me exactly where and what wires I use? Pics would be nice thanks
  10. #50 Re: How to: LED turn signal mirrors
    Jul 2011
    Chicago
    Quote Originally Posted by Logan541 View Post
    When I did mine, I used the Muth installation guide that was downloadable as a pdf
    Exact location, wire colors, and pictures for the 97-03.
    I'm not sure of any changes in location or colors, as mine was an 01. You can look at other GM's for different years, the wiring is mostly the same as other GM brands if needed.
    They only have the installation guide for the 97-03 GP
    http://shop.muthco.com/t/installation
  11. #51 Re: How to: LED turn signal mirrors
    Feb 2010
    TN
    This is awesome thank you so much
  1. Car dies when using turn signal
    By 4boostin in forum General Tech Discussion
    Last Post: 07-28-2010, 05:57 PM
  2. turn signal switch ???
    By bubba40 in forum General Tech Discussion
    Last Post: 07-23-2010, 12:30 PM
  3. Turn Signal Indicator On
    By vega in forum Audio, Security & Visual Electronics
    Last Post: 03-06-2010, 08:43 PM
  4. 04 turn signal?
    By shawns14 in forum General Tech Discussion
    Last Post: 11-28-2009, 10:57 PM
  5. Turn signal Issues
    By jagman454 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-16-2009, 10:39 AM
