Thread: LIM Gaskets: First and Second Design
Results 1 to 7 of 7
  1. #1 LIM Gaskets: First and Second Design
    A question was asked and I figured I'd toss this out in the open as well for general info to all.
    When ordering LIM gaskets on the 3800, there are two listings.
    First design w/o locating pins
    Second design with locating pins
    Soooo what's a locating pin right? On the second design there are two rubber pins on the rubber end seals of the LIM gasket set. 96-97 year engine blocks are technically are the first design w/o pins. 98+ are second design blocks. The difference is not worthy of having two different sets of gaskets. IMO the second design should have superceded the first and only one version should be available as the pins and their function is minimal at best.
    96-97 engine block. Look at the top and bottom of the picture at the block. See the solid line of the block from head to head. That's the first design w/o any holes for locating pins to sit into.
    98+ engine block. Look at the left and right ends of the block. See the two holes on each end. These are where the locating pins sit into.
    When putting second design gaskets on a 96-97 block the pins simply lay over the side and still do the job of holding the gasket in place before the LIM is put back on.
    Aluminum gaskets may be available in both first and second design. Keep in mind that first/second design does not signifiy aluminum vs plastic.
    Easy
  2. #2 Re: LIM Gaskets: First and Second Design
    QC, Canada
    Here's a picture that could be helpful.
    2007 Pontiac Grand Prix GT Supercharged | 105,000 kilos / 65,200 miles
    DEAD (9/28/'13) 2000 Pontiac Grand Prix GT | 161,400 kilos / 100,300 miles
  3. #3 Re: LIM Gaskets: First and Second Design
    If you have a vacuum leak..it's probably from your EGR tube. Just an FYI...lol
  4. #4 Re: LIM Gaskets: First and Second Design
    GT Level Member neel2008's Avatar
    Huntington, IN
    hmm this is interesting because i am getting ready to do LIM gaskets on my 97....so there is like no reason for first design at all really right? I should get the Al second design ones like the felpro MS98014T
  5. #5 Re: LIM Gaskets: First and Second Design
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    yep, get the revised. I dont think they even offer the original anymore
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  6. #6 Re: LIM Gaskets: First and Second Design
    Who has an EGR?
    LOL
  7. #7 Re: LIM Gaskets: First and Second Design
    Even IC'd I had one sitting there for show. Visual emission inspection FTW. They didn't question a think as long as they saw an EGR and evap valve... cause nothing else looked close to stock.
    On the LIM gaskets. I'm just saying that if you are asked first vs second design, there's no reason not to get the second. even if you have the block w/o the holes for hte pins. They'll just hang over.
  1. 3.8 Intake Gaskets 1st or 2nd design
    By bigpaulz28 in forum Off Topic Discussion
    Last Post: 07-15-2010, 12:34 PM
  2. What Box Design for 02 Coupe
    By nicklbmx in forum Audio, Security & Visual Electronics
    Last Post: 05-24-2010, 08:28 PM
  3. Sub box design
    By dagger in forum Audio, Security & Visual Electronics
    Last Post: 08-03-2009, 02:10 PM
  4. SRT Design
    By flash527 in forum Track Sessions and Kills
    Last Post: 07-22-2009, 06:27 AM
  5. Help me design a amp rack!
    By Toofastgs in forum Audio, Security & Visual Electronics
    Last Post: 02-19-2009, 04:19 AM
