Thread: how to fix a heated seat.
Page 2 of 2 FirstFirst 12
Results 21 to 25 of 25
  1. #1 how to fix a heated seat.
    Quincy, Mass
    It most likely is in the top elements. The top kind of clips together on he bottom of it. If you have a steamer for clothes it have help make it easier to put back on when done.
    And look above your post for the relay thing you recall
    No more GP 04 Impala SS Indy:
  2. #2 Re: how to fix a heated seat.
    May 2016
    Montana
    Took mine out and peeled the leather off. tested all connections with Ohm meter and they all read good. put the damn thing back together and reinstalled to check for the relay noise. clicks like it should. seat works fine. must have had a bad harness connection somewhere I'm guessing... Moral of the story? CHECK FOR LOOSE HARNESSES FIRST! I swear I have fixed more GM gremlins by unplugging and replugging the harnesses over the years. hope this saves someone the trouble someday.
  3. #3 Re: how to fix a heated seat.
    SE Level Member smg267's Avatar
    Apr 2016
    killadelphia
    I gotta dig back into this. Where did you test the ohm's for continuity?
  4. #4 Re: how to fix a heated seat.
    May 2016
    Montana
    Quote Originally Posted by smg267 View Post
    The ohms were tested between the start and finish line of the live wire. All over the seat to be sure. Testing anything that I registered in the wire (regardless of numbers ). Tells me there's power and no shorts🤔 Correct?
  5. #5 Re: how to fix a heated seat.
    Nov 2012
    Madison
    Booty heater finally gave out this year.
    Last year it was inconsistent and would turn off.
    I tore into it to find one wire broke, 1 almost severed and 2 with cracked insulation.
    Solder and heat shrink fix now makes my balls warm again.
  1. heated seat
    By ranchero in forum Introductions/Noob Questions
    Last Post: 01-03-2017, 07:35 PM
  2. heated seat
    By Ricky21 in forum General Tech Discussion
    Last Post: 04-23-2010, 10:43 PM
  3. Heated Seat Question
    By StreetChariot in forum General Tech Discussion
    Last Post: 12-03-2009, 01:23 PM
  4. Heated Seat
    By Rather B Blown in forum General Tech Discussion
    Last Post: 12-29-2008, 01:46 AM
