Thread: 04+ GP Radio Light Fix
Results 1 to 20 of 40
  1. #1 Re: 04+ GP Radio Light Fix
    SWPA
    Gonna have a friend of mine do this for me tomorrow. I'm replacing the trans fluid and filter in his wife's car, so he's gonna fix my radio since he has a good soldering pencil and solder sucker. Also helps he's an EE student.
    I'm gonna pick up a few different style bulbs. If I find one that works easily I will be sure to post the p/n.
  2. #2 Re: 04+ GP Radio Light Fix
    Jul 2013
    Bettendorf IA
    Thanks to Bio248 for the detailed instructions and photos that gave me bravery to try repairing the display on my '04 GP GT. I'll pass on a few lessons learned for anybody interested:
    1. Take care with prying off the cover on the radio chassis. The side walls are just rough stamped out and might have sharp edges, as in cut thumb.
    2. Don't waste time and effort on installing the mentioned Radio Shack 25 mA bulbs. They are too weak for daytime display. They just show at night.
    3. "Grain of wheat" 3 mm bulbs are the key, for sure. I didn't find any with solid wires either - only stranded. Instead of eBay, I found the web site of "Ken's Electronic Parts", at Kalamazoo, Michigan. Since I was driving by on a trip, I wanted to bring my burnt ones and compare size and selection. Aside from the mentioned 12 V 75 mA versions, they also cary 14 V 80 mA ones (PH495B) for reasonable price. Since the Radio Shack package mentioned the 25 mA ones were rated at 5000 hr, and my GP has > 4000 engine hours on it, and the voltage regulator is typically putting out > 14 V while driving, I decided to give the 14V ones a try.
    4. If you go for the 80 mA versions, don't cause yourself aggrevation like I did by tinning the stranded wires - then they are a pane to get through the circuit board holes, even after reaming out with a pin. They are mounted and giving good visibility, similar in contrast to the upper display and other red lights around the dash.
    Again thanks for posting the instructions! DD
  1. Radio light is out, how do I fix
    By todd135 in forum Audio, Security & Visual Electronics
    Last Post: 07-26-2010, 07:54 AM
  2. 04 grand prix radio light trouble
    By sasquatch094 in forum General Tech Discussion
    Last Post: 05-20-2010, 05:55 PM
  3. Replies: 16
    Last Post: 01-23-2010, 09:43 AM
  4. Light bulb in radio display question
    By singularity in forum General Tech Discussion
    Last Post: 08-31-2009, 09:30 AM
  5. ABS Light + Check Tire Press. Light Problems
    By element55 in forum Brakes/Suspension/Chassis
    Last Post: 01-30-2009, 02:34 PM
