Thread: Headlight Restoration Under $10
Results 1 to 8 of 8
  1. #1 Headlight Restoration Under $10
    Regal GS Level Member BoostedPontiac's Avatar
    Apr 2014
    South Haven, MI
    First of all youll need a few things:
    1.) Various sandpaper grits. (400,600,800,1500)
    2.) High gloss clear coat. It needs to be uv rated so it wont yellow over time.
    3.) Some paper towels
    4.) A Tupperware container of water for wet sanding
    I started off slow using a coarse grit sandpaper to remove any yellowing.
    After the yellowing was pretty much gone i worked my way down to wet sanding with fine grit sandpaper. After getting the light nice and smooth, i prepped the light for the clear coat by wiping away the plastic headlight dust.
    I ended up letting the clear coat dry, then sanding lightly again to apply a second layer of clear coat. Keep in mind this was just a quick and dirty version. Im sure the results will be better with more sanding/ clear coat. The final results:
    98' GP coupe NIC Pacesetters, E85, FSIC, 2.6, heads, blah
    11.82 @ 118.4 with a 1.8 60ft
    Retired: 99' Regal GS Turbo 11.428 @ 122.61 1.7 60ft.
    Retired: 99 GTP top swap nic setup. 13.37@106
  2. #2 Re: Headlight Restoration Under $10
    you need to reclear them with something that has a little UV protectant or they'll end up looking the same again very soon.
  3. #3 Re: Headlight Restoration Under $10
    Jul 2010
    Coquitlam,BC,Canada
    Like he already did? LOL
    Quote Originally Posted by BoostedPontiac View Post
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  4. #4 Re: Headlight Restoration Under $10
  5. #5 Re: Headlight Restoration Under $10
    GT Level Member QuinlanGTP's Avatar
    Apr 2014
    Chicopee,MA
    Nice write up with pics!
    1998 GTP (COUPE)-160K - Ram Air hood,CAI,SD Headers, Transgo kit, Scotty tune
    2000 GTP (4DOOR)-140K - Gone 2000 GTP (COUPE) - 300K+- Gone now
  6. #6 Re: Headlight Restoration Under $10
    Nov 2015
    Rockford
    I did my fiancee's car headlights with a corded drill, buffing wheel, and plastic polishing compound a while back. No need to paint them after you're done either. Just gotta keep em clean.
    ^before
    ^after
  7. #7 Re: Headlight Restoration Under $10
    Aug 2013
    North Shore
    I happened to see a can of Rust Oleum Triple Thick Glaze clearance priced. It's meant for pottery, but it's high gloss, indoor outdoor (UV), and non-yellowing. I did the refinishing over a year ago and it still looks like new. Granted I park in a garage. Since it was extra thick you can really sand the heck out of it to get the gloss you want.
  8. #8 Re: Headlight Restoration Under $10
    Apr 2014
    South Haven, MI
    Good to know. Ill give that a try next time.
  1. restoration 97 coupe
    By eightballe in forum Visual/Body Modifications
    Last Post: 09-15-2011, 11:18 PM
  2. Headlight buffing/restoration
    By aziff in forum Visual/Body Modifications
    Last Post: 05-14-2011, 02:49 PM
  3. 3M Headlight Lens Restoration System
    By josemolina2008 in forum Visual/Body Modifications
    Last Post: 11-28-2010, 06:43 PM
  4. headlight restoration
    By BIGTMANE in forum Off Topic Discussion
    Last Post: 08-19-2009, 09:59 PM
  5. Headlight Restoration [*]
    By webracin in forum How To Write-Ups/Tech Tips
    Last Post: 06-02-2009, 07:03 PM
