Thread: cv shaft replacement..method two
Results 1 to 3 of 3
  1. #1 Re: cv shaft replacement..method two
    Nov 2008
    Chicago
    A few tips
    1. Don't pull on the axle when trying to remove it from the trans. Pull from the base. My axle separated from the base and made a huge mess.
    2. You can use the 90 degree side of a crowbar to remove it from the trans. Place the short end between the cv and the trans and give the long end some light to medium taps with a hammer
    3. When removing your axle nut, place a 3/8" extension in the vane of the brake rotor to keep it from rotating
  1. CV Shaft Replacement [*]
    By webracin in forum How To Write-Ups/Tech Tips
    Last Post: 01-05-2012, 09:22 AM
  2. rolled fenders....dont use the tommy gloves method.....
    Last Post: 06-09-2009, 12:32 AM
  3. Balance Shaft
    By SyntheticShield in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-13-2008, 10:42 PM
  4. CV Shaft
    By webracin in forum Shops and Community Heroes
    Last Post: 04-15-2008, 01:38 AM
