Thread: How to change camber rods
Results 1 to 13 of 13
  1. #1 How to change camber rods
    Niagara
    Just finished changing my camber rods (originals were bent). Not the hardest job, but thought I would give some info anyway.
    1) Raise car and support on jackstands
    2)Remove rear wheels
    3)Use 2 13/16 wrenches to remove center nuts. (bolts WILL NOT clear the trunk YET)
    4)Remove the nut holding the outer end of the camber rod (13/16)
    5)Loosen (do not remove) the 2 bolts on either side of the crossmember (4 in total)
    6)Pry back the crossmember in order to gain clearance to remove the centre bolts.
    Installation reverse of removal.
    Dont think I missed anything. Also a good time to replace rear sway links.
  2. #2 Re: How to change camber rods
    Norristown, PA
    your names topswap, ever do a topswap?
  3. #3 Re: How to change camber rods
    Niagara
    Not yet, waiting for the spring. I do as little work as possible in the snow. Cant change my name then, so i figured I would sign up with it now.
  4. #4 Re: How to change camber rods
    SE Level Member nault31's Avatar
    Southside Chicago Suburbs
    Any pictures? What about the alignment procedures?
    ^^I realize a stock L36 is not as fast as the sticker implies, but this sticker has worked and it is still a hell of a lot of fun to drive considering it's a grocery sedan.
  5. #5 Re: How to change camber rods
    Niagara
    Sorry, no pictures. It was raining pretty hard. (unusual for january). I will be bringing it in for an alignment tomorrow. Having to lower the crossmember just to pull 2 bolts out is kind of frustrating, but overall, it wasnt too bad.
  6. #6 Re: How to change camber rods
    GT Level Member skidoojames151's Avatar
    seattle
    i dont think those are camber rods, they adjust the toe of the suspension
  7. #7 Re: How to change camber rods
    Donating Users alkygto's Avatar
    Nov 2009
    wentzville
    Okay, went out and looked at my car and the rods are bent. Why? How? and where do I get replacements and how much? Are there any Heavy Duty (Super Duty lol) replacements?
    1997 Pontiac Grand Prix GTP
    1969 Pontiac GTO
  8. #8 Re: How to change camber rods
    Niagara
    I went to the dealer and they call them camber rods, though I could be wrong.
    I ended up buying some used ones from the wreckers. Apparently they are a "dealer only" part. The dealer wanted $199 each. I called the dealer on the american side, and they wanted $103 each (big difference eh?). The wreckers sold me 2 for $25.
  9. #9 Re: How to change camber rods
    Topeka, KS
    Cometic ?
  10. #10 Re: How to change camber rods
    Quote Originally Posted by rynoman03 View Post
    Cometic ?
    They're the gasket guys.
  11. #11 Re: How to change camber rods
    BMR Fabrication Inc.
    DIS
    they're expensive though
  1. Does anyone know where to get camber rods from? (other than dealer)
    By topswap in forum Brakes/Suspension/Chassis
    Last Post: 01-24-2010, 10:16 PM
  2. SC Nose drive change or pulley change
    By jamster00 in forum General Tech Discussion
    Last Post: 06-04-2009, 03:38 PM
  3. Camber
    By SlowM90 in forum Tires & Wheels
    Last Post: 05-14-2009, 06:01 PM
  4. camber bolts
    By nemesis in forum General Tech Discussion
    Last Post: 02-29-2008, 05:10 PM
