Thread: Tail-Lights Tinting [*]
Results 1 to 20 of 27
  1. #1
    I live here. UR LOSN's Avatar
    Rockford, IL
    sounds to me like it wasnt fully cleaned...happens to paint as well.
    if you touch it...the oils form your fingers gets on and doesnt create a good bond between the clear and the VHT. there is a cleaner solution sold at most autoparts stores that cleans the surface completely of all oils. if not use windex...AFTER the nightshades has dried..before the first coat of clear.
    this should help out...if not....I have no idea. bad batch of clear?
    SE Level Member JASON 77's Avatar
    IL
    couple other small things i like to do. instead of the scotchbrite/scuff pad wet sand with 400 grit apply 2 to 3 coats (dark) 1 coat (very pleasing as not too dark) let stand 20 to 30 min between coats, after final coat. wet sand with 1000 grit to get any contaminents/dirt, then apply the clear coat. i use automotive grade to give a great look that lasts.
  1. where to get tail light cover decal
    By Sinister Drag Designs in forum Chevrolet Impala
    Last Post: 07-28-2016, 10:23 PM
  2. Going to tint my tail lights tomorrow, Need good advise
    Last Post: 12-23-2007, 12:55 PM
