Thread: How-to delete EGR.
Results 41 to 60 of 64
  1. #41 Re: How-to delete EGR.
    Well first off your car wont call for as much timing now since you deactivated the EGR (needs to be tuned) and the cylinder isn't being filled with "dead air" so it needs more fuel.
    One can be fixed, one cant.
    Fix one and that should go back up a little.
  2. #42 Re: How-to delete EGR.
    Charles City, IA
    Show me the timing table where it pulls timing when you dont have the egr hooked up.
    SMGPFC Two Nipple General
  3. #43 Re: How-to delete EGR.
    Charles City, IA
    yes and no.
    it lowers combustion temperatures because it is taking up excess space in the combustion chamber since its inert. the only time the EGR is active is during cruise, so there is absolutely no way that someone blew up their motor because they disabled the EGR.
    they could have filled the whole with pea rock.
  4. #44 Re: How-to delete EGR.
    I cant.
    We've had this debate a million times.
    I do not own any tuning software/hardware.
    That is what will told me.
    http://getoverkilled.ca/L67CompProg.html
    Improved MPG on vehicles with EGR disabled through revised timing tweaks
  5. #45 Re: How-to delete EGR.
    Charles City, IA
    Yeah he adds timing in the cruise cells, the car does not pull any timing with out the egr. By adding extra timing you can regain any loss in mileage.
  6. #46 Re: How-to delete EGR.
    This is not how i recall it being explained to me.
    However, I really dont care.
  7. #47 Re: How-to delete EGR.
    Feb 2010
    Flint Michigan
    Well I don't recommend this on a daily driver when you need all the gas milage you can get
  8. #48 Re: How-to delete EGR.
    i barely lost any mileage. you have to run more timing at cruising areas to make good mileage, which the car doesnt have in stock form already.
  9. #49 Re: How-to delete EGR.
    Charles City, IA
    My car still did 30mpg. With no egr.
  10. #50 Re: How-to delete EGR.
    Feb 2010
    Flint Michigan
    mine is 15.4 city and 24 highway, does that seem kind of low to you?
  11. #51 Re: How-to delete EGR.
    Charles City, IA
    Totally depends on how you drive and traffic.
  12. #52 Re: How-to delete EGR.
    Charles City, IA
    I got 30 mpg driving 75 for 5 hours straight.
  13. #53 Re: How-to delete EGR.
    Feb 2010
    Flint Michigan
    well the high way is cruise set at 75 i get 24
    city i get on it some but mostly cruising 15.4.
  14. #54 Re: How-to delete EGR.
    GTX Level Member cliffdawg's Avatar
    Midvale, Utah, United States
    im doing mine but i waiting til i get my tuner before i do it
    SMGPFC #77
    94 Firehawk - #108 of 500
    97 GTP Coupe - Rebuilt Trans, F1 Hood, Front Air Dam, and Gen 5 Blower Swap than done with modding
  15. #55 Re: How-to delete EGR.
    Donating Users Vegas_Matt's Avatar
    Jul 2010
    Las Vegas, NV
    dumb question. if you block the hole coming from the exhaust why would you need to plug the hole in the LIM? there's no air coming or leaving the egr at that point.
    guess i'm just missing something.
    <MiZzBeCcA>its not rape if you yell suprise
  16. #56 Re: How-to delete EGR.
    Donating Users kfish's Avatar
    Ohio
    big ass vacuum leak if you dont block the hole in the lim, dummy.
    <nawarkk> listen maybe I like being gay
    <rynoman03> my dildo i have is old
    <01GTP> my penis is chrome plated
  17. #57 Re: How-to delete EGR.
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    Quote Originally Posted by mattftmfw View Post
    ZZ Performance
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  18. #58 Re: How-to delete EGR.
    my question is can i just leave the tube on the intake tube and do i just let the cord that plugs in the egr dangling down or can i cut it off
    SMGPFC #77
  19. #59 Re: How-to delete EGR.
    Jul 2010
    Las Vegas, NV
    Quote Originally Posted by cliffdawg View Post
    you can leave the egr tubes leading to where they're supposed to go for a "pretend" egr but you don't need to unplug it.
  20. #60 Re: How-to delete EGR.
    unplugging it is awesome.
    granted the codes are deleted and your PCM is setup to increase timing in cruise to make up for the lost MPG.
  1. delete please
    By gotboost3 in forum How To Write-Ups/Tech Tips
    Last Post: 08-30-2009, 01:14 PM
  2. Delete
    By speedemongtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-27-2009, 03:56 PM
  3. EGR Delete
    By Feather Head in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-25-2009, 04:09 PM
