Thread: a/c problem
Results 1 to 2 of 2
  1. #1 a/c problem
    SE Level Member mtz956's Avatar
    browntown
    my 98 GTP dont want to blow air when i turn on the a/c on! i need to know where is the a/c blower is locatad at and how to remove it?
  2. #2 Re: a/c problem
    Ontario
    So you mean air wont blow period even the hot air??? If so your blower is under your dash on the passenger side and theres a few screws in it and it drops out...If you are not getting any cold air then it is more than likely your ac compressor which is the pulley at the very front of the engine by the rad......
  1. MAF problem or is it something else?
    By apdale in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-31-2009, 06:00 PM
  2. car problem....
    By hdc80 in forum General Tech Discussion
    Last Post: 08-27-2009, 07:38 AM
  3. BCM problem
    By Paulio0907 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-19-2009, 04:41 PM
  4. Problem!
    By pure in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-13-2009, 11:07 PM
  5. Hello and a problem
    By Syerix in forum General Tech Discussion
    Last Post: 04-09-2009, 12:57 PM
