Thread: Short Shifter [*]
Results 1 to 20 of 40
  1. #1 Short Shifter [*]
    GTX Level Member webracin's Avatar
    Arkansas
    This write-up is for modifying the shifter, making it shorter, for the Pontiac Grand Prix. The write-up can be found here.
    2001 Grand Prix GTP
    ZZP HUB 3.2 3.4, ZZP 8 Rib conversion, JC 3" DP Gen 2 cat & U-bend Delete, Accel Super Stock 8mm wires, DHP 1.5, 180* Thermo, Throttle Spacer, SS Intercooler, ZZP Fuel Rails, SLP CAI w/K&N Cone, Dynomax cat back, ZZP Tranny.
    2000 Grand Prix GTP Daytona K&N, Flowmasters
    NE Ohio
    thats pretty cool, i never thought of that. it is an auto after all, but its different. i kind of like it.
    SE Level Member SlickGTP's Avatar
    Wasaga Beach, Ontario
    Yeah I think the shifters in our cars are way too tall...
  4. #4 Re: Short Shifter [*]
    SE Level Member BigG's Avatar
    St. Louis
    you said the plunger was too short, at 3/4 inch. how long should it be??
  5. #5 Re: Short Shifter [*]
    GT Level Member BackInBlack's Avatar
    Vermont
    Has anyone removed the gate between D and 3 so you can shift down without depressing the button? I was going to on my '97, but never got around to it...
    The GPs are long gone...
  6. #6 Re: Short Shifter [*]
    Moore,OK
    just did this last weekend and like it soooo much better. it no onger feels like a ford aerostar shifter. wasn't as hard as i thought it would be. just take your time and measure twice and cut once.
    99 gtp
    14.7@92mph 2.1 60ft .290 r/t STOCK
    :SOLD: Mistake
    2005 GXP???
  7. #7 Re: Short Shifter [*]
    Apr 2008
    Chillin at the Beach , VA
    That is pretty nice. Like the whole look of it.
  8. #8 Re: Short Shifter [*]
    May 2008
    McHenry IL
    ahhh man looks gnarly i wanna do this but im afriad ill break something so nvm haha
  9. #9 Re: Short Shifter [*]
    so do we cut the yellow piece to size?
  10. #10 Re: Short Shifter [*]
    Moore,OK
    yes. you will have to cut it to length and grind the sides down so it will fit into the knob. in his write up he said to cut it to about 3/4". i actually left mine a little long and kept test fitting the knob
    99 gtp
    :SOLD: Mistake
    2005 GXP???
  11. #11 Re: Short Shifter [*]
    May 2008
    McHenry IL
    i might actually do this soon =] is there anything i can screw up? also i have a GTP WITH performance shift on my shifter sooo... any differnt ?
  12. #12 Re: Short Shifter [*]
    i took everything apart to the point of the cutting part, but i got lost. the diagram said to measure 1.5" but aside from the yellow plastic piece, am i also suppose to cut/trim the metal sleeve as well along with the indented markings?
  13. #13 Re: Short Shifter [*]
    Moore,OK
    Quote Originally Posted by GTPJOE90 View Post
    no. it's exactly the same. just make sure you don't pinch the wires for the perf. shift button.
    99 gtp
    :SOLD: Mistake
    2005 GXP???
  14. #14 Re: Short Shifter [*]
    Moore,OK
    Quote Originally Posted by fst View Post
    yes. but when you cut the metal shaft don't just cut straight through it. you want to be careful not to cut through the yellow plastic piece. you want to trim all around the metal shaft untill you cut through it. it took me about 20min. to finally get through it. then once that's done you can trim the yellow piece down to approx. 3/4"-1". i think mine worked out to be right around 7/8". after you cut the yellow shaft you will have to sand it down as it's to thick to fit into the shifter knob and then cut the grooves into the metal shaft. use the piece you cut off as a guide on how far down to cut. the two long groves/slots (running from top to bottom) are you shifter knob alignment slots. these are what keep your knob from turning. the other two slots are the locking slots where the metal u-clip slides into.
    99 gtp
    :SOLD: Mistake
    2005 GXP???
  15. #15 Re: Short Shifter [*]
    SE Level Member PRIXSY's Avatar
    Feb 2009
    Pennsylvania
    OK THIS IS A HEAD SCRATCHER FOR ME, SINCE I SAW UR HOW TO, IM WAS ASKING MYSELF IF MAYBE U MITE KNO SOMETHING ABOUT MY ISSUE, MY GEAR SHIFTER BUTTON STAYS STUCK. WHY I DONT HAVE A CLUE BUT I HAVE TO BANG ON IT MORE THAN SEVERAL TIMES TO LOOSEN IT UP IN ORDER TO PUT IT INTO GEAR. ANY IDEA??
  16. #16 Re: Short Shifter [*]
    Moore,OK
    have you done the short shifter mod? if so you might need to take the knob back off and grind down the sides of the yellow shaft.
    if you haven't done the mod i would take the knob off and spray some wd-40 down the shaft. mine was kinda gummed up when i did the mod and a quick squirt of wd-40 freed it up
    99 gtp
    :SOLD: Mistake
    2005 GXP???
  17. #17 Re: Short Shifter [*]
    SE Level Member StreetShaker's Avatar
    Feb 2009
    Tyrone, Central PA
    Dumb. That looks retarded.
    Proud Member of the Central PA Wrecking Crew
  18. #18 Re: Short Shifter [*]
    GTX Level Member kingd44's Avatar
    Feb 2008
    newyork
    not as retarded as u hahahahahahahahahahaha
    180 t-stat, wizaired cai, s&s headers, 3inch cat back exhaust,jpg plug wires, auto lite plugs, 3.4 pulley, and ovk pcm......rockers to come............next summer might go intercooled
  19. #19 Re: Short Shifter [*]
    CT
    That actually looks pretty pimp. It does stick up way to far and gets in the way of things if you ask me.
  20. #20 Re: Short Shifter [*]
    SE Level Member deangtp's Avatar
    Kansas City, MO
    I did this today. I did it in the car though. A little messy but it'll clean up.
  1. Short Stack Intercooler [*]
    By webracin in forum How To Write-Ups/Tech Tips
    Last Post: 04-30-2012, 04:20 PM
  2. Modification Page
    By webracin in forum Site/Club News
    Last Post: 12-14-2007, 03:38 PM
