Quote Originally Posted by Quicksilver_GP View Post
okay...im confused, the 5 button DIC and trim plate setup that Ed Morad sells isnt just a plug and play type of thing? or if you were to do it the "plug and play" way then you would have to have your odometer sent off to be reprogrammed? So this is why you did this mod the way you did as opposed to just plug and play?
the DIC brain tracks mileage, in adition to the speedometer cluster. if you dont care that they match, you can just plug it in and go. if you want the mileage to be correct, you need to have the mileage programmed into the DIC. (way around this is if you could find a DIC that had a bit more miles than your car, then when your car is to that same mileage, plug it in) -- tricky to catch the exact mileage perhaps though.
