I've dropped 5 or so of these into Regals. Found that cutting is very easy with a rotozip cutting bit for wood/plastic inserted into a dremel tool with flexhose end. It gives you great flexiilbility to move in the confined space.
If you don't have the wiring, add it..it's only 8-12 wires that you can tap into right at the cluster connector.
Yeah the whole time i was cutting in the odd spaces i kept thinking that there had to be an easier way to do this! Wished mine had come with a flex hose, I can see how that would have def made things easier!! Thanks for the info bill!!
