There are five screws, three in each fenderwell, and two underneath holding the fenderwell to the fascia, then two 10mm bolts on the inner fenderwell, by where you put a FWI. Take out all the pushpins on the lower fascia, and the 7mm bolt right in the middle of the bumper. thats it, easy as that.
*edit: don't forget the push pins that hold the radiator cover plastic to the fascia either, and just pull straight out. let me know if you have more questions.*
..and the white triangle piece stays.. it just slides forward. It took me like a half hour to realize that. haha
Dont forget to unplug to fog lights!!!! Dont touch thr bulbs with your fingers because the oils on your hands will make the bulbs burn out.
Here it is C&Ped from ClubGP
