Thread: Removing gaskets off soft metal (3M Roloc)
Results 1 to 20 of 22
  1. #1 Re: Removing gaskets off soft metal (3M Roloc)
    Wichita, KS
    Quote Originally Posted by 99prixgt View Post
    I carefully used a razor blade
    Not saying you cant use them, they work yes, but there is a better, safer way.
    I just kept getting cores sent in, or cases sent in for work where somebody had used a gasket scraper, or a razor blade obviously, and just hacked the crap out of em. Looked like some were drug behind a car on a gravel road. Its sad to see, so made a video showing that there is a much better safer way to do it, for those who are not skilled enough to use a blade.
    Not saying you HAVE to do this or use this method, for every job, there is always another way to go about doing it.
    ~F~
  2. #2 Re: Removing gaskets off soft metal (3M Roloc)
    Jersey
    Quote Originally Posted by GR8racingfool View Post
    ~F~
    Agreed. Im glad you posted this method, I will definitely try using your method next time . It was extremely tedious using a razor blade, I had to keep changing blades every 5 seconds because they would dull and get jagged, your method is much more care-free.
    16' wrx sti- stock
  1. Metal Clip
    By Red97GPGT in forum Brakes/Suspension/Chassis
    Last Post: 03-24-2009, 09:00 PM
  2. What do you use? (gaskets)
    By TDCRacing in forum Off Topic Discussion
    Last Post: 01-27-2009, 04:07 PM
  3. Metal Gas Tank Flap Broken off and Into Tank
    By indplsin72 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-15-2008, 08:35 PM
  4. Metal Shavings
    By GTPluv in forum Off Topic Discussion
    Last Post: 04-02-2008, 11:53 AM
  5. LS1/LS2 metal oil cap overlay
    By Preotic in forum Visual/Body Modifications
    Last Post: 03-01-2008, 09:57 AM
