Quote Originally Posted by ZeroAK View Post
I too had a bunch of issues removing the hubs on my 04. I started by whacking them with a big hammer, didn't work. I then used a gigantic slide hammer that attached to the lug studs, rapped on it a few times, and I thought my axle was gonna fly out. That knocked it loose enough that I could use a fairly large punch in the center of the axle spindle and release the hub. Now my problem lies in the passenger side where one of the bolts has rounded off..........anyone have any suggestions, its the forward most knuckle to hub mounting bolt.
We just did a set on a 99 Regal. If you round the bolt you'll have to cut through it with a SawZall or grinder with cutoff wheel on the outside. Just cut down through the bearing and avoid the knuckle. The stealership charged me $7 for a bolt. One of mine was stubborn, the other easy. Forget the flange puller or slidehammer. If it's stuck use an OTC 7394 or similar with an impact gun. Its built like a tank, no worries..............
