Thread: Home Brew Coldish Air Intake Gen 1
Results 1 to 14 of 14
  1. #1 Home Brew Coldish Air Intake Gen 1
    SE Level Member Daermos's Avatar
    Mar 2016
    Ogden, Utah
    Ok so i did a Home Brew Intake for my 3800 SC, was able to get all these parts from Oreilly Auto Parts and a Hardware Store.
    4" ABS Piping
    3.5" to 4" Couplar
    1" 4" Specter Couplar
    1" 4" Specter Air Filter.
    This is Gen 1 Design, currently thinking of reworking and trying and inline 6" Specter right into the wheel well
  2. #2 Re: Home Brew Coldish Air Intake Gen 1
    hangover park IL
    if you ge the rubber 4" 90" elbow, you cut it in the middle about 30-45* and it clamps directly to the tb lip while connecting to the 4" pvc and then filter
    ~James~ Psychotic Gearhead
  3. #3 Re: Home Brew Coldish Air Intake Gen 1
    Mar 2016
    Ogden, Utah
    Thanks for the Input i am possibly going to try to modify the intake and see if i can can get it to fit into my wheel well. Not sure as of yet though. I have been looking for a DIY to build a enclosed cold air box that i can completely close off the filter and run a intake pipe into the wheel well.
  4. #4 Re: Home Brew Coldish Air Intake Gen 1
    I prefer directly behind the head light instead of the fender well. Less chance at dirt flying up and making it to the filter and large puddles of water aren't your friend.
    Either way it don't make much of the difference, temps will be the same once moving and airflow into the engine bay. Niether will make more power than the other or anything like that.
  5. #5 Re: Home Brew Coldish Air Intake Gen 1
    I break things. WarStryker13's Avatar
    Oct 2014
    Frederick, MD
    Fender well is only cooler during slow, stop and go traffic. I have one that is sheilded on the bottom to prevent mud and water splashing up to the filter, but it's mostly for show. Speaking of which I need to take some pics of how I had it before. Lol
    04 GP GT2: Handling upgrades, go-slow parts, and an attitude. Totaled.
    87 Dodge Ram 50:​ Junkyard rescue, resurrection in progress.
  6. #6 Re: Home Brew Coldish Air Intake Gen 1
    hangover park IL
    best cold air intake is a turbo
  7. #7 Re: Home Brew Coldish Air Intake Gen 1
    Oct 2014
    Frederick, MD
    ^^^^^ troof!
  8. #8 Re: Home Brew Coldish Air Intake Gen 1
    GXP Level Member Grimsin's Avatar
    St Thomas Ontario
    ya but turbos don't like 4t65e's, they usually give them the smackdown lol
    3.8l N/A POWA! :4'' HAI\L67 HVTB\HV3\ER Rockers\WP underdrive pulley\Headers\cat delete\91 octane overkill incar tune.3.69 gears, Trans go shift kit.
    My Car:http://www.grandprixforums.net/threa...2005-Impala-LS
  9. #9 Re: Home Brew Coldish Air Intake Gen 1
    Mar 2016
    Ogden, Utah
    Quote Originally Posted by WarStryker13 View Post
    Yes if you could post some pics, i have been pretty happy with my gen 1 that i built but i am thinking of directing it more towards the fender.
  10. #10 Re: Home Brew Coldish Air Intake Gen 1
    GTP Level Member buickman104's Avatar
    NYC
    Here is the J Performance stage 1 fender well intake.
    2000 Bronze Metallic GTP
    Power :Gen V, 3.6 pulley, 3 inch down pipe, Power log, FWI,and DHP Power Tuner,
    Handling: Vogtland Springs, GMPP sway bars, STBS, 18" Konig backbone, CTS-V Front brakes and GXP rear brakes
  11. #11 Re: Home Brew Coldish Air Intake Gen 1
    Kemmerer, Wyoming
    keep it simple silly. take all that plumbing sh!t off and clamp the air filter onto the throttle body and call it good. the IAT sensor doesn't need to be in the air flow to give accurate readings to the pcm. just let it dangle or something. I noticed you live in Ogden, there is a Utah 3800 club on facebook. if you want to join that group I can give you more info.
  12. #12 Re: Home Brew Coldish Air Intake Gen 1
    Mar 2016
    Ogden, Utah
    Quote Originally Posted by SgtMarshal View Post
    Info for that local group would be awesome, looks like you have a slightly different intake than I do what gen is that?
  13. #13 Re: Home Brew Coldish Air Intake Gen 1
    Kemmerer, Wyoming
    this is when I had an intercooler with a gen 3, north star throttle body and lq4 mass air flow sensor. the idea is the same with the L67 throttle body, and is how my air filter is on now. here is a video of it running, the idle lope is because there is an XP cam in there. I'll pm you my facebook page so you can send me a pm and I'll pass the word to the admin.
    http://vid1115.photobucket.com/album...pscuoe2wc6.mp4
    https://www.facebook.com/groups/530171857046278/
  14. #14 Re: Home Brew Coldish Air Intake Gen 1
    SE Level Member pipewelder91's Avatar
    Jul 2016
    I used the stock airbox lid and slid it over the tubing behind my filter after coating it with high temp paint and then used exhaust wrap on the entire intake up to the filter, looks kinda strange but youd be surprised the difference it made
    Sent from my SM-G930V using Tapatalk
  1. Spectre filter home made intake $25
    By Shuff in forum For Sale - Parts
    Last Post: 09-15-2013, 08:40 AM
  2. Home made intake
    By jman44 in forum Introductions/Noob Questions
    Last Post: 07-10-2013, 12:17 AM
  3. how to make a cold air intake at home.
    By drewprix86 in forum How To Write-Ups/Tech Tips
    Last Post: 12-31-2010, 05:03 PM
  4. doin a home cold air intake system i found.
    By drewprix86 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-23-2010, 09:28 PM
