Thread: Headlight Restoration [*]
Results 1 to 15 of 15
  1. #1 Re: Headlight Restoration [*]
    Oklahoma
    This is true. Look at it this way. The clear coat method will give you a barrier between the plastic of the capsule and all the debris and stuff that may hit your headlight. Furthermore, all the maintenance that would be required afterwards would be using the other method of just going over it with a few steps of sandpaper and then polishing. Just like you would for paint and such.
    All you really have to watch for using my method is cracking in the clear coat. Its really best to just put it on several coats and build it up some. The high temp clear I was using seems to be thicker than Im used to, so it didnt seem to run very easy. However, it seems to want to crack. But Im also not convinced thats not due to temperature either. I was on the borderline of the cutoff temps recommended for painting. Once it warms back up here I'll try and do more sets. Id like to do this as a service locally. Ive also learned a lot in the few sets Ive already done and have been working on some improvements in the proceedure.
  2. #2 Re: Headlight Restoration [*]
    SS-DD Level Member IndeedSS's Avatar
    St Louis MO
    Could there be a way to continue with a smaller grit paper until it becomes clear w/o painting? We used to used Brasso to bring hazed or scratched watch crystals to life. This also worked well with CB radio power meter lenses.
    04 Indy SS build #972 - Traded
    2010 Camaro SS LS3
  1. headlight covers
    By bad1999gtp in forum Visual/Body Modifications
    Last Post: 01-07-2008, 10:37 PM
  2. 1997 Grand Prix Headlight Glue FTL!
    By flynn in forum Visual/Body Modifications
    Last Post: 01-04-2008, 03:26 PM
  3. Headlight rewire
    By dsgtp in forum Visual/Body Modifications
    Last Post: 12-17-2007, 11:31 PM
