Thread: How To: LED Fog Lights/Stock Brackets (97-03)
Results 1 to 10 of 10
Threaded View
  1. #1 How To: LED Fog Lights/Stock Brackets (97-03)
    Jul 2010
    Coquitlam,BC,Canada
    Copying how I did my previous Piaa/HID/Fog set-up, I started with some Morimoto XB LED for lights from The Retrofit Source, some stock fog lights, and some old 9007 and 880 bulbs; I kept the HID wiring harness in play, so needed and adapter harness to go from 9007 to 880.
    The XB LED kit:
    Stock lights from the junkyard:
    Remove the lenses from the stock lights:
    Remove all this crap from the XB LED’s:
    Apply adhesive to the inside edge of the stock housing, and to the outside edge of the LED light and join the two together:
    After the adhesive has cured, remove the glass from the 880 bulb and solder it to the LED light wires:
    Lights are done:
    Bench test:
    Remove the glass from the 9006 bulbs, solder wire to them, then solder the other end of the wires to the 880 plug:
    Attach the stock bracket to the lights (they aren't pretty, but you won't see this part of them in a few minutes):
    All done!
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  1. Stock headlight brackets 97-03
    By SomeDudeAtHome in forum Wanted To Buy - Parts
    Last Post: 10-09-2014, 11:14 AM
  2. GMPP Sway bar bushings into stock brackets?
    By JBONE in forum Brakes/Suspension/Chassis
    Last Post: 06-29-2010, 04:13 PM
  3. Brackets for Pilot fog lights......
    By Iron Indian in forum Visual/Body Modifications
    Last Post: 12-04-2008, 01:35 AM
