Thread: How To: LED Fog Lights/Stock Brackets (97-03)
Results 1 to 10 of 10
Bronco Boy How To: LED Fog Lights/Stock... 09-14-2016, 03:36 PM
Bronco Boy Re: How To: LED Fog... 09-14-2016, 03:36 PM
Bronco Boy Re: How To: LED Fog... 09-14-2016, 03:39 PM
coolone Re: How To: LED Fog... 09-14-2016, 07:21 PM
Bronco Boy Re: How To: LED Fog... 09-14-2016, 10:13 PM
coolone Re: How To: LED Fog... 09-15-2016, 05:40 PM
Swiggles Re: How To: LED Fog... 09-17-2016, 11:49 AM
Bronco Boy Re: How To: LED Fog... 09-17-2016, 08:57 PM
Swiggles Re: How To: LED Fog... 09-18-2016, 03:59 PM
Bronco Boy Re: How To: LED Fog... 09-18-2016, 06:34 PM
  1. #1 How To: LED Fog Lights/Stock Brackets (97-03)
    Jul 2010
    Coquitlam,BC,Canada
    Copying how I did my previous Piaa/HID/Fog set-up, I started with some Morimoto XB LED for lights from The Retrofit Source, some stock fog lights, and some old 9007 and 880 bulbs; I kept the HID wiring harness in play, so needed and adapter harness to go from 9007 to 880.
    The XB LED kit:
    Stock lights from the junkyard:
    Remove the lenses from the stock lights:
    Remove all this crap from the XB LED’s:
    Apply adhesive to the inside edge of the stock housing, and to the outside edge of the LED light and join the two together:
    After the adhesive has cured, remove the glass from the 880 bulb and solder it to the LED light wires:
    Lights are done:
    Bench test:
    Remove the glass from the 9006 bulbs, solder wire to them, then solder the other end of the wires to the 880 plug:
    Attach the stock bracket to the lights (they aren't pretty, but you won't see this part of them in a few minutes):
    All done!
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  2. #2 Re: How To: LED Fog Lights/Stock Brackets (97-03)
    Jul 2010
    Coquitlam,BC,Canada
    Output shots:
    And some shots with the projector headlights on (fogs are 5500K, headlights are 5K):
    Full write-up is here: http://chrisb.users.superford.org/Gr...og_Lights.html
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  3. #3 Re: How To: LED Fog Lights/Stock Brackets (97-03)
    Jul 2010
    Coquitlam,BC,Canada
    Comparison shots (5000K HID H3 on passenger side, 5500K LED on drivers side).....
    HID:
    LED:
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  4. #4 Re: How To: LED Fog Lights/Stock Brackets (97-03)
    Nov 2011
    NY
    Nice job, interesting as I was looking at these, XB setup. I think it needs to sit a little more forward, but is good stuff.
  5. #5 Re: How To: LED Fog Lights/Stock Brackets (97-03)
    Jul 2010
    Coquitlam,BC,Canada
    Quote Originally Posted by coolone View Post
    Nice job,
    Thanks.
    I think it needs to sit a little more forward.....
    I agree. That is the one thing still bothering me. I've been thinking about a spacer to go between the bumper and light mount, maybe 1"; I meant to do a side by side comparison of these lights and the old ones, but I missed that step. LOL
    Here is how my old lights sat:
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  6. #6 Re: How To: LED Fog Lights/Stock Brackets (97-03)
    Nov 2011
    NY
    Yes, I think because the output is so much more intense, and to get some additional side lighting, I would bring it forward a bit. Will probably do the XB Led's soon and will benefit from your trial and error ; ) hehehe, but they do throw a lot of light for sure.
  7. #7 Re: How To: LED Fog Lights/Stock Brackets (97-03)
    Quincy, Mass
    Why not just get a 880 hid harness for the fog harness?
    No more GP 04 Impala SS Indy:
  8. #8 Re: How To: LED Fog Lights/Stock Brackets (97-03)
    Jul 2010
    Coquitlam,BC,Canada
    Quote Originally Posted by Swiggles View Post
    1) I already had the current harness
    2) I wasn't sure if the LEDs would be staying
    3) Making the harness cost me nothing but a few minutes to make
    4) I could have just used the stock 880 plugs, but see #2
    Hows that?
    If I do decide to keep these LED's, I will remove the old HID wiring harness/ballasts' and return to the stock wiring plugs.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  9. #9 Re: How To: LED Fog Lights/Stock Brackets (97-03)
    Quincy, Mass
    Lol #1 would've been fine. But why solder to the 9007 bulbs socket, just change to 880 plugs.
  10. #10 Re: How To: LED Fog Lights/Stock Brackets (97-03)
    Jul 2010
    Coquitlam,BC,Canada
    I had typed 9007 in the write-up. It should read 9006 and has been edited.
    The HID harness is a 9006 plug where it connects to the ballast; unplug ballast, plug HID harness into my adapter harness, then to the LED's. Now if I want to return to the old lights, I can.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  1. Stock headlight brackets 97-03
    By SomeDudeAtHome in forum Wanted To Buy - Parts
    Last Post: 10-09-2014, 11:14 AM
  2. GMPP Sway bar bushings into stock brackets?
    By JBONE in forum Brakes/Suspension/Chassis
    Last Post: 06-29-2010, 04:13 PM
  3. Brackets for Pilot fog lights......
    By Iron Indian in forum Visual/Body Modifications
    Last Post: 12-04-2008, 01:35 AM
