Thread: 2000 non supcharged GP GT Dies at start up after up to temp.
Results 1 to 10 of 10
  1. #1 2000 non supcharged GP GT Dies at start up after up to temp.
    Apr 2011
    Ohio
    Hello my 2000 Grand Prix GT with 222,000 miles non supercharged 3.8 with no codes starts fine when its cold but after its up to temp and you shut it off and then restart it, it fires up then dies. I've heard the resistor might be out. Anybody now the replacement part NO. and where to buy? Dealer item only? Thanks
  2. #2 Re: 2000 non supcharged GP GT Dies at start up after up to temp.
    Jul 2012
    Chicago
    Sounds like a crank sensor.
    -Carl
  3. #3 Re: 2000 non supcharged GP GT Dies at start up after up to temp.
    Sep 2014
    Worcester, MA
    If you give it a little throttle, will it stay running? I've heard of dirty intake air passages around the butterfly that can get clogged and mess with the airflows at idle.
  4. #4 Re: 2000 non supcharged GP GT Dies at start up after up to temp.
    Mar 2014
    Tucson
    I'd start simple. Is the throttle body and IAC clean?
  5. #5 Re: 2000 non supcharged GP GT Dies at start up after up to temp.
    you dont have a high speed resistor.
    could be a fuel pressure regulator. or a dirty TB.
  6. #6 Re: 2000 non supcharged GP GT Dies at start up after up to temp.
    Apr 2011
    Ohio
    Yes the throttle body is clean but haven't checked the IAC, and yes if I give it a little throttle for about 10 seconds it will stay running.
  7. #7 Re: 2000 non supcharged GP GT Dies at start up after up to temp.
    Dec 2012
    Where 4T65E's were born
    Think scotty is pointing in a good direction, especially if the tb is clean. Pull the vacuum line off of the fuel pressure regulator and make sure there is no fuel in it. You can do this with it running or not running. I have personally taken one off while running, and seen gas squirt out of it.
    And yeah, 2 speed fuel pump is a supercharged thing.
    Sold.
  8. #8 Re: 2000 non supcharged GP GT Dies at start up after up to temp.
    Apr 2011
    Ohio
    Just checked the fuel pressure regulator and there is NO gas coming out.
  9. #9 Re: 2000 non supcharged GP GT Dies at start up after up to temp.
    Apr 2011
    Ohio
    IAC was cleaned today, car is better but still stalling.
  10. #10 Re: 2000 non supcharged GP GT Dies at start up after up to temp.
    have the car scanned anyway. you could have a code pending.
  1. Replies: 0
    Last Post: 06-29-2012, 01:08 AM
  2. 2000 GTP dies!
    By RandalK in forum General Tech Discussion
    Last Post: 02-02-2011, 03:39 PM
  3. 97 3.1L wont start, stumbles and dies
    By atxjax in forum 3.1L V6 (LHO/LG8)
    Last Post: 06-16-2010, 03:18 AM
  4. 2000 dies while driving?
    By turbostang7 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-04-2010, 11:20 AM
  5. 2000 3.8 gp dies
    By redrivergar in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-05-2008, 07:07 PM
