Thread: Transmission temp,
Results 1 to 5 of 5
  1. #1 Transmission temp,
    SE Level Member MGRead's Avatar
    Jun 2012
    Coral Spring, Fl
    I have a 2004 grand prix GT2 with on a auto transmission. What should the transmission fluid temp be at? avg. outside is 85-92. she been from 210-221 after 35 mins of driving with the a/c running.
    Any help?
  2. #2 Re: Transmission temp,
    Sounds about right.
    I know my car after long drive periods, it will always stay right at coolant temp, so 195-205.
    04+ cars always seem to run hotter for some reason. Buying a trans cooler can greatly decrease the temps.
    Just to note, any temp above 215-220ish reduces the trans fluid life by alot more than you think. Prolly 10-15k miles.
  3. #3 Re: Transmission temp,
    Yoga city
    mine never gets above 210, well not since the first day i had her, she was a little low
  4. #4 Re: Transmission temp,
    New York
    If you plan on keeping the car for a long time, definitely run an efficient double stack cooler (the biggest one you can fit in the grille) or better yet do like I do and run the cooler (S) outside of the radiator-I use dual 18,000 GVW Long double stack coolers. Temp runs about 145 on a 90 degree day-anything over 190 will kill the transmission prematurely! I have zero issues in the extreme cold as well-Just takes the tranny a little longer for the fluid to get hot enough before shifting into 4th (above 88 degrees fluid temp).
    Jun 2012
    Coral Spring, Fl
    I'm looking into replacing my radiator and added a 2 one to the tran. If that dose not help I will be replace my tran with a new one.
  1. Normal transmission temp for GXP?
    By Snik225 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-29-2012, 02:20 PM
  2. Coolent temp Goes to regular temp and drops down?
    By Lukesgrandprix in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-11-2012, 08:11 AM
  3. Transmission temp and other questions
    By 707chance in forum 5.3L V8 (LS4)
    Last Post: 06-09-2009, 12:12 PM
  4. temp on aeroforce and temp on dash
    By jacobmh27 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-25-2008, 01:05 PM
