Thread: E85 tuner
Results 1 to 20 of 28
  1. #1 E85 tuner
    GTP Level Member Rlugo87's Avatar
    Jun 2016
    Minnesota
    Hey guys, I am looking for someone who can tune my pcm for e85. I am currently going to use method Tim from zzp suggested, 42# injectors, Casper hotwire, Voltage booster along with 4ga power wire from alternator, high flow filter. I am going to mix 50/50 93/e85 on this setup. But next month I am going to cough up for the aem e85 pump and I would like to have a specific tune to run full e85 at that time. I have several pcms laying around that I could ship out to someone willing to help. Thanks in advance.
    Sent from my Moto E (4) using Tapatalk
  2. #2 Re: E85 tuner
    you are gonna out flow the 42's once you go full corn. gonna need 60's at min. so get all your parts in order and just do it once.
  3. #3 Re: E85 tuner
    Jun 2016
    Minnesota
    Already purchased 42's and before mentioned things. I did get them at a very decent price so I left myself room to upgrade to 60's without taking a huge hit by buying injectors twice. I don't plan on running below a 3.4 pulley on the 42's. My intensions are eventually go with an intercooler setup and a 3.2 on full corn. I feel like my 112k trans will bite it about then tho. No symptoms of a bad trans yet but I haven't ever "not" had to rebuild a 4t65
  4. #4 Re: E85 tuner
    you can push that pulley to a 2.8 asap on e85 and a ic. any smaller and you need to mill the blower snout.
  5. #5 Re: E85 tuner
    Jun 2016
    Minnesota
    So maybe you can sorta tell me if my setup is going to halfass work, will the 50/50 corn mix support a 3.4 with no kr? My current mod list is u bend delete, plog, intake, digital horsepower tune. I see up to 3* of kr at the top of second this kr goes away in 3rd, also no kr on downshifts and only blips of less than 1* on launch. My new "used" dog done seem to have worn bushings so maybe in getting some false kr too. But I know false kr is seen in spikes and my kr in second climbs with rpm to almost 3*
  6. #6 Re: E85 tuner
    Oct 2011
    Toledo, OH
    Again... 42.5s and 3.4 runs E85 just fine...
    Also Rlugo, I have a brand new 320lph AEM E85 pump I can give you a deal on. I didn't like how it fit my 05 canister so I got an 05+ specific one.
    7"
  7. #7 Re: E85 tuner
    Jun 2016
    Minnesota
    Quote Originally Posted by industrialfish View Post
    I will definitely be in touch on that, I blew my whole wad this week on car stuff. I budget my build around being able to spend one paycheck per month on cars or car related stuff. This gives me about 700 per month I can have fun with. I got burned by a guy on fb on a snout and zzp hub. He last minute forgot his PayPal password asked me to Walmart him the cash and has since not responded, lesson of the day is PayPal only and shell out the fees for goods or service. I'm going to give this dude the opportunity to respond to me by Monday if not I will definitely be exposing him on FB and here just in case you guys cruise the 3800 marketplace on fb.
  8. #8 Re: E85 tuner
    May 2008
    Schuyler, NE
    42# injectors will support down to a 3.2 pulley on e85, so you'll be good.
    I'm a little confused as to what Tim is selling you though. If you stick the 42# injectors in and fill up with e85, you technically don't need a tune. You also don't have to mess with mixing gas and e85 either.
  9. #9 Re: E85 tuner
    Jun 2016
    Minnesota
    He is saying if I run straight e85 I will kill my pump asap. He agreed the 42's on a stock tune would work. If course this all could be an upsale.
  10. #10 Re: E85 tuner
    May 2008
    Schuyler, NE
    Quote Originally Posted by Rlugo87 View Post
    Yeah, it won't kill the pump. Just make sure you change the fuel filter after switching, and you'll be fine. Get a caspers or racetronix rewire on there as well. A stock pump will supply enough fuel to get you below a 3.0 pulley in most cases.
  11. #11 Re: E85 tuner
    Jun 2016
    Minnesota
    I ordered a Casper hotwire kit, voltage booster, and 4ga alt power cable.
  12. #12 Re: E85 tuner
    May 2008
    Schuyler, NE
    What year is your car?
  13. #13 Re: E85 tuner
    42 are done on corn with a stock pulley. if you tune them your maxed out. ive seen this 3 times so far, you need 60's.
    that 42 install is for untuned stock.
  14. #14 Re: E85 tuner
    May 2008
    Schuyler, NE
    Then how do we run smaller pulleys with 42's?
    Stock injectors work on e85....
  15. #15 Re: E85 tuner
    Oct 2011
    Toledo, OH
    Stock will not. Stock #33s are already at %85-%90 IDC.
    7"
  16. #16 Re: E85 tuner
    May 2008
    Schuyler, NE
    It's been done. At 85-90 idc, there is a lot of fuel left yet.
  17. #17 Re: E85 tuner
    on gas they are fine. like i said, seen em maxed out asap as soon as you tune them for corn.
    no tune, no mods but corn and they work ok.
    i maxed out my stock injectors on gas, why i have 42's now. so how the hell you running modded with corn on stock crap injectors???? oh thats right, your not.
  18. #18 Re: E85 tuner
    May 2008
    Schuyler, NE
    I ran 42's on e85 and a 3.4 pulley for a good year. I still had plenty of injector left.
  19. #19 Re: E85 tuner
    you take that risk. its so close to max it may as well be maxed out.
  20. #20 Re: E85 tuner
    May 2008
    Schuyler, NE
    As I said, 85-90 idc shows that there is a lot of fuel left.
    42's will support 340 chp on e85. So, unless a stock engine magically gains 100hp from just switching to e85, you are wrong.
  1. 97-03 DHP or HP tuner, off board tuner and top 1/2 L36 parts
    By Scottydoggs in forum For Sale - Parts
    Last Post: 10-25-2018, 07:46 PM
  2. WTB: DHP Tuner
    By GrandPrixGT1 in forum Wanted To Buy - Parts
    Last Post: 08-06-2017, 12:46 PM
  3. Replies: 1
    Last Post: 06-13-2012, 05:46 PM
  4. I think I need a tuner....
    By 01gtspecial in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-28-2009, 06:18 PM
