Thread: AC Clutch Grind
Results 1 to 3 of 3
  1. #1 AC Clutch Grind
    Jan 2016
    Gerogia
    Hello everyone, I greatly need you guys assistance and suggestions.
    Basically a couple months ago, my car used to make this grinding noise, the problem was intermittent. Now the problem came back in the winter and it hasn't faded away like before. I narrowed the problem to my AC clutch, I do not know if it is the whole clutch of just the bearing, I figured it was just easier to replace the whole clutch since it has the bearing included.
    Also, a couple weeks ago when I would press the AC button, I would here it kick in. Just now I tried to test the AC to see if the clutch kicked in, the clutch would not engage.
    What could be the problem of this? Could it be that the AC clutch is just in its entirely, going bad and causing it to not engage? Was it caused because I let the noise happen for a while now and it just eventually messed with the clutch?
    Thank you guys, your advices are greatly appreciated!
  2. #2 Re: AC Clutch Grind
    Jan 2016
    Gerogia
  3. #3 Re: AC Clutch Grind
    St. Louis
    Check the wiring harness going to it and make sure it's not rubbed through or cracked somewhere. All else fails grab a compressor and swap it out. I usually don't mess with just changing the clutch since its a PITA, I just do the whole unit and done.
  1. Trying to locate the grind.
    By Bluemagic in forum General Tech Discussion
    Last Post: 07-15-2013, 12:12 PM
  2. Things that really grind my gears
    By Peacher213 in forum The Rant Forum
    Last Post: 01-27-2013, 02:58 AM
  3. Factory State of Grind
    By BlackGT97 in forum Off Topic Discussion
    Last Post: 01-09-2012, 08:23 PM
  4. Mysterious grind only while braking
    By techweenie in forum Brakes/Suspension/Chassis
    Last Post: 06-20-2011, 07:06 PM
