Thread: Heater blower trouble ....
Results 1 to 14 of 14
  1. #1 Heater blower trouble ....
    Pittsburgh PA
    My fan seems tO want to work at random.... Perhaps a lose wire but not sure... As it will slowly spin up and cut out and spin up and cut out until it reaches max force.... Sometimes it won't do anything when starting car and I have to tap on the dash some for it to start to spin.... Any ideas?
  2. #2 Re: Heater blower trouble ....
    Topeka, KS
    Replace the Fan. The brushes in the motor are probably bad.
    Morad Parts Company - 3800 Motors, Transaxles, & Stock Parts
  3. #3 Re: Heater blower trouble ....
    KSteelwheelzJ klj5022's Avatar
    New Carrollton,MD
    ^^^What he said when the brushes start fading it will come in and out sometimes when you hit a bump till it finally goes
    I just wish the police loved my car as much as i do 3.5,160 Stat,HAI,ZZP F/R STB, SSAC Headers, Reptile PCM
  4. #4 Re: Heater blower trouble ....
    Pittsburgh PA
    Thanks I'll take a look at that... It just seemed to occur too random and inconsistent to be somethin major.... Like I can sometimes go for days even weeks without it happening then out of the blue it won't spin up... Then I hit a bump and oh look it's good
  5. #5 Re: Heater blower trouble ....
    west springfield, pa
    Definately the blower motor. Mine was making all kinds of noise and then finally quit. Bought new blower and problem fixed. I finally have heat again!
  6. #6 Re: Heater blower trouble ....
    Pittsburgh PA
    Yeah I'm gonna check all my fuses tommorow and make sure it's not it new blower is on the way but if it's just a fuse... Won't hurt to throw a new motor in it anyways... I'll hopefully have heat again before I freez to death in this 0 degree weather
  7. #7 Re: Heater blower trouble ....
    michigan
    you can use a test light to see if its the blower motor theres a plug on it check to make sure you have power to the plug and away from the plug if you do its the motor
  8. #8 Re: Heater blower trouble ....
    GTX Level Member Confusingboat's Avatar
    Minnesota
    I had a similar issue, and it was really interesting to diagnose. I took the motor out, and as long as it wasn't sitting upright it would work just fine. I finally figured out that when I pushed slightly downwards compressing the actual blade assembly it would give that extra umph to allow the motor to start.
    What happened was water got down under the motor and sat on the panel beneath it and froze. The expanding of the water into ice pushed the armature of the motor slightly upwards causing it to become misaligned internally thus producing less power, making it intermittently operable. I just set the thing down on concrete and tapped on center of the plastic blade assembly with a hammer to push it back down. It's been fine ever since.
    2004 Grand Prix GT2 - SOLD
    2015 Evo MR
  9. #9 Re: Heater blower trouble ....
    Pittsburgh PA
    @ confusingboat...
    Yeah I think that you and I are were having the same issue... Unfortunately my car has to sit outside therefore I think your reply is spot on... My reasons are last week my car would not blow heat at all avg temp was around 17 last week... This past weekend it was aroun 38... Now I was just jammin and drivin home from eating hit a couple easy bumps in rapid succession and wha la... My face was met by a burst of heat and my blower has been working for three days now... Question. Is the blower motor difficult to get to it seems like it's gonna be tough
  10. #10 Re: Heater blower trouble ....
    Pittsburgh PA
    @mylast post
    I have 2004 gt1
  11. #11 Re: Heater blower trouble ....
    Minnesota
    There's a panel on the passenger side underneath the glovebox. There are 3 push plugs that hold it up, so just pull them out and the panel will fall down. Turn the bulb socket to get it out of the panel. Move the pass. seat all the way back and lay down so you're facing up under the dash. You can't miss the blower motor, it's the big circular black thing mounted by 3 bolts (7mm I believe?). Just remove the bolts and it'll drop right out. Trace the wires to the firewall and the little black box it connects to is the blower motor resistor, which might be bad (but probably not). You can test the motor by hooking it up to any 12v power supply, provided it supplies enough current.
    2015 Evo MR
  12. #12 Re: Heater blower trouble ....
    Jan 2012
    North Andover, MA
    Thanks for your reply about the blower motor and the resister!!! I'm going to work on that right now!!! Thanks again!!!
  13. #13 Re: Heater blower trouble ....
    May 2016
    Douglasville, Ga.
    If you lose power on blower/AC & auto headlights plus info center, could be ignition wiring harness. I first replaced blower motor resister but would still lose power that feeds resister which in turn feeds the blower motor. I read from another forum if that happens check for power in the fuse box inside glove box on right side. Bottom of fuse box second roll up, second fuse from left is a 20 amp fuse. If you experience this check for around 12 volts. My son's car would lose power and when I used V.O.Meter it would show only 2.5 volts. The ignition switch/harness is inside the steering column but not impossible to change out yourself. That said problem is gone.
  14. #14 Re: Heater blower trouble ....
    damn someone is digging deep. 4 year old thread. welcome to the site. good first post at any rate tho lol
  1. ac/heater blower problem
    By edman thomp in forum General Tech Discussion
    Last Post: 08-26-2010, 08:03 PM
  2. Heater and AC trouble...I need HELP!
    By Smalltownmodder in forum Introductions/Noob Questions
    Last Post: 04-27-2010, 02:20 AM
  3. heater blower and hud
    By lokie81 in forum General Tech Discussion
    Last Post: 09-16-2009, 06:27 AM
  4. Heater Blower
    By stratojet in forum General Tech Discussion
    Last Post: 03-22-2009, 09:58 PM
  5. Heater Blower Problem
    By duncanmi in forum General Tech Discussion
    Last Post: 11-24-2008, 09:46 AM
