Thread: clock resets sometimes after starting my car
Results 1 to 2 of 2
  1. #1 clock resets sometimes after starting my car
    pa
    My clock resets sometimes after I start my car. could this be a battery problem? car cranks normal and the alternator is charging. Thank you.
  2. #2 Re: clock resets sometimes after starting my car
    St. Louis
    Pull both the battery cables and clean them until they shine then clean the battery side as well. Then just make sure they are good and tight when you re-install them. Sounds like a ground issue to me.
  1. pcm resets when i turn car off
    By 05grandprix05 in forum General Grand Prix Discussion
    Last Post: 03-22-2015, 12:01 AM
  2. Dash/Raido Resets When Turning - 08 Base Model
    By Nic8524 in forum General Grand Prix Discussion
    Last Post: 05-13-2012, 04:56 PM
  3. Clock spring
    By jpearsall187 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-30-2011, 07:50 PM
  4. Random PC resets
    By Xorbex in forum General Tech Discussion
    Last Post: 09-15-2010, 12:35 PM
  5. Clock.
    By Dohner in forum Forum Bugs/Suggestions
    Last Post: 02-13-2009, 10:41 PM
