Charging system failure followed by battery saver active when it dies it resets everything and starting disabled comes bk on dic sometimes bypass is needed others its not... I've changed starter, battery, alternator, terminal wires, electronic ignition switch all the fuses are new relays all look good... car starts engine runs just fine then suddenly after driving a while or car being on a while battery will die even while in drive it starts to idle really slow, lights dim, then engine shakes and kills... idk what to do next
Sent from my SM-J260AZ using Tapatalk
