Thread: On '01 GTP, battery keeps showing low voltage
Results 1 to 3 of 3
  1. #1 On '01 GTP, battery keeps showing low voltage
    Donating Users NotEnoughGPs's Avatar
    Aug 2013
    Pittsburgh, PA
    On a 2001 GTP with 31,000 miles that I purchased two years ago, I keep having the issue of the battery showing 9 volts or less.
    I drive the car only occasionally. Each time I do, I take a fully charged battery (either a Sears Diehard Platinum or Optima redtop) from another car and install it in the GTP. It starts right up and I drive it anywhere from 20 to 30 miles.
    I monitor the Aero Force Interceptor gauge at the start of the drive and it reads around 13 volts. I usually drive at highways speeds.
    Upon returning home at low speeds of less than 20mph and letting the car idle in the driveway, I notice the headlights and interior lights dimming. Then the antilock brake light flickers on and off. The Interceptor gauge reads as low as 9 volts.
    If I shut off the engine, the car will not restart.
    After hooking up a Sears charger to the battery, the car will restart after a few minutes of recharging.
    The gauge read 10 volts or so, and will continue to drop.
    If I install the battery in another one of my GP's, the engine will start right up.
    Also, I have made sure the battery terminals are free of corrosion (I have never seen any corrosion on any of the GP's I have ever owned)
    Note: There is no aftermarket stereo in the car.
    Also note: Car has many modifications, one being a trunk mounted pump to cool the supercharger.
    What could be causing the voltage to drop so drastically?
    Alternator? As far as I know, the original one is in the car.
    Wiring from alternator to battery?
    Battery cables?
  2. #2 Re: On '01 GTP, battery keeps showing low voltage
    Feb 2015
    Could be a parasitic draw that the alternator can't keep up with at low speeds or idle. If it looks like the factory alternator I'd have it bench tested to see if it's up to par. Even though the car only has 31000 miles the alternator is 14 plus years old.
    Sent from my SAMSUNG-SM-N910A using Tapatalk
  3. #3 Re: On '01 GTP, battery keeps showing low voltage
    Most likely the alternator needs a new regulator.
  1. New Battery, New Alternator, Battery still dies. Any Ideas?
    By bjornbjorn in forum General Tech Discussion
    Last Post: 03-19-2015, 10:05 PM
  2. battery voltage
    By bluebsh in forum General Grand Prix Discussion
    Last Post: 02-24-2015, 02:36 PM
  3. Showing off my new rims :D
    By LePrix in forum Tires & Wheels
    Last Post: 11-02-2011, 01:06 AM
  4. thought this pic was worth showing
    By DaytonaGTP in forum Off Topic Discussion
    Last Post: 12-22-2010, 08:35 PM
  5. Why is my signature not showing up?
    By Hayden in forum Forum Bugs/Suggestions
    Last Post: 09-16-2008, 01:36 PM
