Thread: 8 rib idle pulleys
Results 1 to 7 of 7
  1. #1 8 rib idle pulleys
    Regal GS Level Member BoostedPontiac's Avatar
    Apr 2014
    South Haven, MI
    Does anyone have the part numbers for wider (8 rib) pulleys? Id like to not spend $85 from zzp. I did search a few different ways and came up with nothing. I already have a 5% overdrive balancer so all i need now is the 2 smooth and 1 ribbed pulleys.
    98' GP coupe NIC Pacesetters, E85, FSIC, 2.6, heads, blah
    11.82 @ 118.4 with a 1.8 60ft
    Retired: 99' Regal GS Turbo 11.428 @ 122.61 1.7 60ft.
    Retired: 99 GTP top swap nic setup. 13.37@106
  2. #2 Re: 8 rib idle pulleys
    Apr 2014
    South Haven, MI
    http://www.grandprixforums.net/threa...n+part+numbers
    Never mind, i found this. Im saving about $40 going through rock auto.
  3. #3 Re: 8 rib idle pulleys
    Quote Originally Posted by BoostedPontiac View Post
    Smiling ear to ear here..I think you are the first to ever find that on your own
  4. #4 Re: 8 rib idle pulleys
    Apr 2011
    Elk Rapids, Michigan
    I'm glad that a search led me to this thread! It will save me over $30 from what ZZP gets for the 3 pulleys! Thanks Bill!
    2001 black GTP coupe, Gen V, ZZP S2IC & billet fuel rails, XP cam, LS7 lifters, 105# springs, ZZP MPS w/3.4 pulley, Northstar tb, LQ4 maf, ZZP headers, K & N CAI, Meziere electric wp, Caspers fp retire, F body front brakes, GMPP strut braces​, Don Rome strut brace mounts.
  5. #5 Re: 8 rib idle pulleys
    I break stuff selliott's Avatar
    Kansas City
    Smooth flow has them as well
  6. #6 Re: 8 rib idle pulleys
    Kemmerer, Wyoming
    why do you need 8 rib? when I had my 2.8 on it didn't slip at all.
  7. #7 Re: 8 rib idle pulleys
    still smiling. lol
    All I did was find the right offset and pulley size.
  1. P0171 and P0300 Codes, Mildly Rough Idle, Rough on starts, Slightly Elevated Idle
    By nskyline34 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-17-2021, 07:49 PM
  2. Rough Idle with intermittent idle miss
    By 99GTPMLA in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-09-2012, 12:12 PM
  3. Won't idle; missing above idle if you can get it started
    By jrece in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-27-2011, 11:24 PM
  4. Running rich at idle, causing idle issues.
    By matt5112 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-22-2010, 09:16 PM
  5. High / Fast Idle - Idle Air Control motor?
    By porshuh in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-30-2009, 11:28 AM
