Thread: Dex Coolant
Results 1 to 12 of 12
  1. #1 Dex Coolant
    Sep 2015
    Sacramento
    I'm hearing a bad reputation for Dex coolant... Wears down the gaskets quicker than other coolants?
    http://www.dex-cool.net/
    I'm doing an intake manifold swap, and going to be flushing my coolant system.
    Should I avoid Dex cool once I do so?
  2. #2 Re: Dex Coolant
    Dex would turn to oat back years ago. Formula's have changed many times since. Ford, Dodge and GM all went to nylon based gaskets and had issues. That particular part wasn't the coolant's fault. It was either neglect to do maintenance (coolant exchange) or it was nylon gaskets. Hence why GM fixed the issue with metal frame gaskets.
  3. #3 Re: Dex Coolant
    Sep 2015
    Sacramento
    Are you saying if I swap to metal gaskets I should not see the sludge again? (After doing a complete flush on the coolant system of course)
  4. #4 Re: Dex Coolant
    I break stuff selliott's Avatar
    Kansas City
    Personally I'd still swap over to green. But that's just me, after having multiple issues with dexcool I won't use it no matter how many times they reformulate it.
  5. #5 Re: Dex Coolant
    Quote Originally Posted by KennethJohnson View Post
    sludge is from air making contact with the old dex coolant. flushing it to clear water, then adding a flush to it will clear most of it out, you'll still find a booger here and there on the rad cap after wards down the road. nothing to worry about.
  6. #6 Re: Dex Coolant
    Quote Originally Posted by selliott View Post
    Green is not suited to the amount of aluminum in our systems. Green is not a good replacement.
    Use Anycolor and smile after flushing it to death.
  7. #7 Re: Dex Coolant
    GTP Level Member
    Aug 2012
    st louis park, MN
    http://www.napaonline.com/Catalog/Ca...EXT_0417656901
    This is what I bought. It may be green but it is for all makes and models. The compatibility chart says its fine for our cars.
    2008 Grand Prix Base: Engine cover delete , flipped dogbone bushings, Transgo shift kit, Hayden 403 trans cooler,
    Quote Originally Posted by Yarbeau View Post
    we are all anal about our vehicles. Otherwise we would not be on an extinct platforms forum debating 3000 dollars cars!
  8. #8 Re: Dex Coolant
    Kansas City
    It looks like mine is universal as well just green in color
  9. #9 Re: Dex Coolant
    GT Level Member Brammer's Avatar
    Feb 2009
    Roanoke, VA
    If I know one thing from my short time here it's that if it comes out of BillBoost's mouth you should trust it.
    ....except that thing he said about my mom.
  10. #10 Re: Dex Coolant
    Kansas City
    Don't know about the mom thing lol but the rest is true.
  11. #11 Re: Dex Coolant
    FIREFIGHTER/AEMT
    Dec 2013
    williamsport tennessee
    i found that nissan green works just fine, since thats what i have on tap at the dealership i work at......NEVER dexcool
    1998 grand prix gt 2 door
    2006 ram 2500 cummins diesel 4x4
    2015 NISSAN Rogue SL (wifes ride)
  12. #12 Re: Dex Coolant
    GTP Level Member Impala131's Avatar
    Knoxville, TN
    I tore down a 99 GTP (200K miles) to replace the LIM gaskets as a preventative measure... the factory plastic gaskets were actually in good shape, considering the age/mileage. The previous owner religiously changed coolant every year. Fresh dex is perfectly fine, although not sure how long it takes for dex to become acidic.
    That said, the replacement metal LIM gaskets are still good insurance.
    2003 Grand Prix GTP.... the journey begins again....
    E85 Self Tune with HPT, 80# Injectors, Gen V 3.4 pulley, SD Headers, AL605 Plugs
  1. LIM side coolant port modification / coolant block off
    By 2004l67 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-16-2015, 02:56 PM
  2. Coolant reservoir has brown junk in it and low coolant light flashing. what is it?
    By JessicaRebel in forum General Grand Prix Discussion
    Last Post: 09-15-2014, 08:37 AM
  3. Flashing Low Coolant Light, Coolant Full, No leaks
    By KZOO3800 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-12-2012, 08:25 PM
  4. low coolant light...but not so much low coolant..?..
    By 1lilcountrygrl in forum General Tech Discussion
    Last Post: 08-08-2010, 12:29 PM
