Thread: It won't even crank :(
Results 1 to 5 of 5
  1. #1 It won't even crank :(
    Oct 2014
    Detroit
    Alright guys I probably should've posted a while back but I've been pretty busy... so about 2 wks ago on a friday I drive my car home and the car starts up and idles rough, then it revs to about a 3k and it stalled. It's an 02 GTP but I tried to bend the relay to bypass the resistor anyway... didn't work. It would crank and idle roughly till it just wouldn't start anymore. Later that weekend I got in the car and all the lights were out... so a dead battery. I left it like this for a week (it's been a busy week), so last weekend I jumped it, it started and idled rough but once I turned it off it wouldn't turn on again and the lights dimmed again... so I replaced the battery and well now it just does this (I linked the video below) ... what the hell?
    https://www.youtube.com/watch?v=VxODcExGpmI
  2. #2 Re: It won't even crank :(
    Loose connection somewhere is my guess.
  3. #3 Re: It won't even crank :(
    Oct 2014
    Detroit
    Hmm maybe in the battery terminals? Don't know why it'd start up with it jumped but when the new battery's installed it won't start at all
  4. #4 Re: It won't even crank :(
    Donating Users NotEnoughGPs's Avatar
    Aug 2013
    Pittsburgh, PA
    I also have been experiencing issues with the electrical system in a '02 GP. I have not had the cranking issue like JohnJ89 has. The cause may be totally different. But, after doing plenty of searching of electrical problems on the 3800, a lot of problems can be caused from bad connection to the battery.
    In my GP, the engine is slow to start up, even though it is tuned up, starter is working ok, and the battery is brand new. After the engine starts, the idle will sometimes be rough. And the dash lights and DIC and interior lights will glow bright, then get dim.
    The battery side post cable bolts that hook up to the battery are the original ones. The negative terminal bolt has been stripped out for some time. I can turn it with my fingers.
    Others that have had no startup or slow starting, and rough idle, and dimming lights have pointed to the fact that there must be a secure fit of the battery cables to the battery in these cars. So, even though the side bolts are twisted into the battery, they are not making enough of a connection for electrical current to flow.
    So, I am going to try replacing the bolts to see if that makes a difference.
  5. #5 Re: It won't even crank :(
    Jun 2015
    Clearwater, FL
    Sounds like you've found your problem, that weak ground connection can cause all kinds of issues
  1. No crank, just click. Replaced starter, still no crank.. help!!
    By Steve98GTP in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-17-2013, 08:48 PM
  2. No crank. Replaced starter, still no crank. Now what.
    By suctoes in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-13-2013, 01:22 AM
  3. 3 wire crank sensor vs 2 wire with 24x crank trigger
    By greenmachinegtp in forum PCM Tuning
    Last Post: 03-12-2012, 05:45 PM
  4. Car Won't Crank..Again
    By brandonl2000 in forum General Tech Discussion
    Last Post: 07-30-2010, 12:58 PM
