Thread: Write-up/tech tips for Ignition Switch bypass procedure?
Results 1 to 5 of 5
  1. #1 Write-up/tech tips for Ignition Switch bypass procedure?
    Donating Users NotEnoughGPs's Avatar
    Aug 2013
    Pittsburgh, PA
    I replaced the ignition switch on '02 GP. After getting the new switch in place, I want to do the ignition switch bypass procedure so that the current will bypass the contacts in the ignition switch itself and flow through the relay. Is there a write-up on how to install and wire up the relay for this?
  2. #2 Re: Write-up/tech tips for Ignition Switch bypass procedure?
    Jul 2010
    Coquitlam,BC,Canada
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  3. #3 Re: Write-up/tech tips for Ignition Switch bypass procedure?
    Aug 2013
    Pittsburgh, PA
    Thanks for the quick response.
    I was searching for BackInBlack's post on this ignition switch bypass procedure on ClubGP, but had no luck (searching on ClubGP for old write-ups is difficult at best). There is a thread on the bypass procedure under the write-up section, but the link to the procedure would not load.
    Anyways, I will locate the relay and wires and get this going. I had an ignition switch from an another GP that I installed into my 40th Anniversary GP and so far, the contacts are showing no signs of going bad.
  4. #4 Re: Write-up/tech tips for Ignition Switch bypass procedure?
    Jul 2010
    Coquitlam,BC,Canada
    Quote Originally Posted by NotEnoughGPs View Post
    No problem. I just did this to my new uninstalled switch a few weeks ago. FYI, the write-up is in the "Upgrades" section of ClubGP.
    Yet. LOL
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  5. #5 Re: Write-up/tech tips for Ignition Switch bypass procedure?
    Aug 2013
    Pittsburgh, PA
    Also, any chance on getting this Ignition Switch bypass procedure put on the "How To" section?
  1. can i bypass the ignition switch to get heat
    By stanwich in forum How To Write-Ups/Tech Tips
    Last Post: 12-10-2013, 11:05 AM
  2. Grand Prix Tech Tips Link
    By moddman in forum How To Write-Ups/Tech Tips
    Last Post: 05-11-2012, 04:10 AM
  3. Car lurching, tech said maybe throttle switch, does this make sense?
    By tcman49 in forum General Tech Discussion
    Last Post: 08-02-2011, 07:19 AM
  4. Tech tips = how to?
    By matt5112 in forum Forum Bugs/Suggestions
    Last Post: 12-19-2010, 05:21 PM
  5. tech tips section
    By Toasty in forum Forum Bugs/Suggestions
    Last Post: 07-10-2008, 11:39 AM
