Thread: magnasteer rack and pinion replacement problem 2004 grand prix gpt
Results 1 to 11 of 11
  1. #1 magnasteer rack and pinion replacement problem 2004 grand prix gpt
    Aug 2015
    nebraska
    Changed out my 2004 Grand Prix leaking rack with magnasteer and replaced it with a rack with magnasteer out of a 1999. Filled it with oil and it turned great standing still, drove it down the street went to turn and no power steering at all, does it need reset or is something else wrong??
  2. #2 Re: magnasteer rack and pinion replacement problem 2004 grand prix gpt
    SWPA
    You probably still have air in the system. You need to bleed it out by idling in place and turning lock to lock several times with the cap off. You'll need to add more fluid once any air pockets work themselves out.
  3. #3 Re: magnasteer rack and pinion replacement problem 2004 grand prix gpt
    Aug 2015
    nebraska
    [QUOTE=Ct04] Thanks for the input ,I tried your suggestion still no power steering , fluid level is full, pump doesn't whine like it does when its low, acts like a valve closed and won't open. this is my first reply I hope I'm doing this right.
  4. #4 Re: magnasteer rack and pinion replacement problem 2004 grand prix gpt
    jack the wheels off the ground, car off, turn the wheels lock to lock 10 times. that will bleed the air out of the rack.
  5. #5 Re: magnasteer rack and pinion replacement problem 2004 grand prix gpt
    Aug 2015
    nebraska
    Quote Originally Posted by ScottyDoggs View Post
    thanks worked like a champ
  6. #6 Re: magnasteer rack and pinion replacement problem 2004 grand prix gpt
    Enfield, CT
    Interesting cause the GM service manual says not to turn to lock to lock.
    Sent from my LG G3
  7. #7 Re: magnasteer rack and pinion replacement problem 2004 grand prix gpt
    SWPA
    Quote Originally Posted by HighOctaneRacing View Post
    Sent from my LG G3
    Well it is GM afterall....
    Ever since power steering came to be turning lock to lock was the method for bleeding
  8. #8 Re: magnasteer rack and pinion replacement problem 2004 grand prix gpt
    GXP Level Member
    Mar 2015
    Tomball
    Sent from my LG G3
    So what does the FSM say?
    Jeff
  9. #9 Re: magnasteer rack and pinion replacement problem 2004 grand prix gpt
    its the only way to bleed the air, other wise its air bound. every how to rack swap ive seen says to do that. even bill says to do that.
  10. #10 Re: magnasteer rack and pinion replacement problem 2004 grand prix gpt
    awesome news. FU GM hand book lol
  11. #11 Re: magnasteer rack and pinion replacement problem 2004 grand prix gpt
    GXP Level Member
    Mar 2015
    Tomball
    Lol
  1. 04+ Rack and Pinion replacement [*]
    By UR LOSN in forum How To Write-Ups/Tech Tips
    Last Post: 09-26-2017, 01:31 PM
  2. Rack and Pinion replacement time.......
    By traildog in forum General Tech Discussion
    Last Post: 03-10-2014, 07:12 AM
  3. Rack and Pinion Replacement Dilemma
    By quickster in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-13-2012, 06:19 AM
  4. Rack & Pinion 04 Grand Prix GTP S/C
    By dblisle in forum Brakes/Suspension/Chassis
    Last Post: 05-28-2012, 09:04 PM
  5. Rack and Pinion replacement.
    By aeidian in forum Brakes/Suspension/Chassis
    Last Post: 10-10-2011, 03:33 PM
