Thread: Help Deciphering Torque App Test Results
Results 1 to 5 of 5
  1. #1 Help Deciphering Torque App Test Results
    GTP Level Member bonerjamz03's Avatar
    Apr 2009
    Upper Darby, PA
    I ran the Torque App vehicle test earlier and here are the results. Not sure what the failed tests are about and I searched online to no avail. Idle quality has been kind of rough for a while now and sometimes there is hesitation when I accelerate. Cylinder 4 has a random misfire here and there (Brand new plugs & wires). I just installed headers with a high flow cat and replaced both O2 sensors a few weeks back. Any ideas?
  2. #2 Re: Help Deciphering Torque App Test Results
    No idea what any of that stuff means, phone apps are useless to me.
    But I come from using real live data scanners in the shop I work in and my HP Tuners software.
    As for the misfire, have you swapped a coil around yet or swapped over the ICM from a known running car just to test it and see if the misfire goes away?
  3. #3 Re: Help Deciphering Torque App Test Results
    Apr 2009
    Upper Darby, PA
    No not yet, I'm gonna play around with it tomorrow.
  4. #4 Re: Help Deciphering Torque App Test Results
    Feb 2013
    Missouri
    I haven't run those tests before, I just look at misfires and LTFT's while the symptoms are going on to help determine the problem. You can trust phone apps if you have a descent phone. Most phones these days have more system resources and processing capabilities than a lot of computers do. If you don't have the phone loaded up with crap software to use up all the system resources, it can be trusted.
  5. #5 Re: Help Deciphering Torque App Test Results
    SE Level Member thekidinbuff's Avatar
    May 2013
    Buffalo, NY
    All this is, is the tests that the ECU runs to test the different systems.
    This will help:
    https://www.scantool.net/forum/index...3.0;attach=936
    The link directly downloads.. its a PDF.
    Are you getting a check engine light?
    2002 Pontiac Grand Prix GTP
    2006 Pontiac GTO LS2 M6
  1. Compression test results?
    By Jcinstalls in forum 3.1L V6 (LHO/LG8)
    Last Post: 04-05-2015, 10:58 AM
  2. My e-test results with no catalytic converter, Thx again Overkill.
    By Grimsin in forum General Grand Prix Discussion
    Last Post: 02-05-2014, 04:33 PM
  3. Compression test results
    By Nickell in forum General Tech Discussion
    Last Post: 12-02-2013, 08:23 PM
  4. Torque App Sensor Test Results
    By Thompsju in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-13-2013, 02:07 PM
  5. Torque app results
    By rvnwlf in forum PCM Tuning
    Last Post: 06-05-2012, 08:32 PM
